something in-between chip socket and chip?
joe34
448CR
hi folks,
i got a rom burner recently (im new to it all, i have not owned/used one before),
what i was wondering was, i have myself an open hardware cartridge for use with the C64, and i realised that i dont like the idea of keeping having to remove the eeprom from its socket on the pcb and then into the burner, and back and forth (the legs on the chip wont last very long i expect, especially knowing me...)
is there some kind of inbetween socket i can add to the eeprom, so then im only ever pulling out/pushing in that socket rather than putting strain on the eeprom legs themselves? (if there is some kind of socket i can use could someone post eg. an ebay link or just a picture would be fine, so i can then go look around for the socket)
ps. edit: my first thoughts of course were 'well just use another socket, dummy!"
i'm just checking in to see if there is anything i am missing/should know etc, tips about this sort of stuff
thanks!
joe342019-04-21 13:44:16
Brettster
1,276CR
if there's no case on the cartridge then yes, A Zif socket would be ideal, just lower the leaver to clamp the IC in raise it to remove the chip with no force needed
https://ebay.us/HU27Kp
you may need to twist the pins on the bottom of the Zif Socket though to fit it in the pcb socket
Brettster2019-04-21 13:50:56
joe34
448CR
just got back in from work, thanks for the suggestions, ah nuts that zif socket looks ideal, i already soldered a regular socket on the pcb last night though
hmm maybe i guess i will just have to get another regular socket and use that, so the chip will never leave that new socket and any strain etc will occur on the new socket legs rather than the chips legs
favouredson
Super Star
1,260CR
As Brettster states, you can just stick the ZIF in the regular socket.
I have one on my home-made 2532/2732 adaptor and it makes things a lot easier. No hassle and much quicker and easier than trying to lever the IC out every time.
joe34
448CR
thanks yes i think the zif sounds like a good idea i expect i will go for that then
(anyone have a spare one?) aha
