Sony PVM 20M4E Vertical Issues
jerryspaghetti
37 (100%)
1,995CR
Took a flyer on a partially working PVM on ebay that was cheap and relatively local. Just seeing if I can get some input from the community to help me get it fully working.
I'm waiting on delivery of BNC cables to test with a proper video source but the menu is coming up although it is only the top half that's visible.
I've looked into PVM issues and have only found one issue that could be connected. So i'm thinking it could be vertical fold over from someone adjusting the vertical blanking to get rid of the RGB lines that appear when certain caps are going bad. I'm going to replace those caps first and see where it gets me.
If that doesn't work i'll try replacing the vertical output transistor as i've read that if you adjust the vertical blanking to hide the RGB its a temporary fix and can cause bigger issues when the caps go all the way bad.
If anyone has experienced this problem please let me know if you solved it and how.
Will update when I have fully tested with BNC cables next week but wanted to get a headstart!
