I've got two faulty ZN-2 based games :Tetris TGM and a G-Net PCB.
Tetris TGM runs on the Capcom version of the ZN-2 PCB - and I get no audio out of it at all, if I feed a signal into the amp I get sound so it looks like the audio part of the PCB is dead.
The G-Net PCB is faulty, it just keeps rebooting instead of loading from the CF card, also the Bios wont update and gives an erase error and an address when you attempt to update it.
So I thought I'd try and swap the two top boards over to get one working PCB out of the two - no dice I get a blue screen with "system error and a number (which I assume tells you what the system error is).
I've gone over the PCB's with a magnifying glass and there are some differences.
1) there's a bank of resistor pads: on the Taito version it's on connection "T", on the Capcom version it's on connection "C"
2) IC652 a 20-pin dip chip? is labelled CP10 on the Capcom and TT10 on the Taito and that's the only chip on the bottom board I can spot that's different between the two versions.
One is labelled "CAT702", "103090-00203", "9838", "0092". [/b]
the other "CAT702", "103090-00203", "9749", "0084" - So I assume this is what makes the boards unique.
[/b][/b]
3) The Taito PCB is marked COH-3002T 1-665-825-11 and the Capcom one COH-3002C 1-665-825-12 so there is some subtle difference between them.
Anyone know enough about ZN-2 hardware to help me swap these over? I assume I need to change the Resistor location and swap IC652 - but what is it?
Taito version with resistor moved from T to C.
Capcom version.
[/b][/b]
Capcom version.
