I have come to an end with the work on Space Gun for now! I have a lot of projects in queue, so my main priority is to get everything up and running in an acceptable condition.
The inside of the cabinet is covered with a very thin vinyl which had gone brittle and curled up near the back of the cabinet. I glued it back on. Not very nicely, I might add. But it looks OK from the front.
There were some loose wooden pieces, so I clamped and glued them too.
The back door had split into at least 2 pieces. It looked like these two fit together, so I screwed it back on. I later painted all the worn areas black.
I'm not sure where this part was supposed to go. Is it supposed to go on a door or the cabinet?
I didn't find any use for it.
I noticed that the lock of the back door (just a hole at this point) was visible inside the cabinet when playing, which I found annoying. I couldn't find any information about it, but I decided to turn the back door upside down instead. Does anyone know if it's supposed to be like that, or am I missing something to hide the lock from the player's view?
I purchased some special thumb screws to fasten the pedal part to the cabinet. My kickpanel door was missing, and I couldn't find any information about it. I can see that they may have intended for a drawer-like construction, but wouldn't that make it impossible to pull the door because of the pedals?
I decided on a simpler design, with two nail irons (not sure what they are called) which go into the slots in the bottom of the cabinet. They were rectangular originally, but I didn't like the sharp edges, so I used the belt sander to make them rounder.
It works very well, and the door isn't going anywhere.
I know I should have chosen something like plywood or mdf, but I couldn't find anything with the right thickness.
Finding the right colour was a struggle! I tried to match the cabinet's red colour with a Pantone colour wheel. To make a long story short, the paint I got didn't match at all. It was some kind of dull pink, and it looked terrible!
I remembered that I had bought a bucket of blood red paint for Halloween, and that turned out to be a much better match!
