Space Invaders L shape missing sound
virtvic
The Cabaret King
21 (96%)
2,012CR
As mentioned in another Tech post, the Midway Invaders L shape board I have has a missing motherboard sound. When I first played it, t was just making a droning sound when the top mothership went by, but now the sound is completely missing.
I'm pretty sure it will be a failed TTL chip, but is the mothershipp sound a particular one that I could just replace?
EDIT - After some minor googling, it may have something to do with a 76477 at H2 - I'll pull the pcb out later and check it out. I'm pretty sure I won't have that component though
virtvic2018-07-28 19:43:44
virtvic
The Cabaret King
21 (96%)
2,012CR
UPDATE _ FIXED!
I pulled the pcb to have a lookee around and noticed the socket that the 76477 is in had been replaced at some point (rather badly) and one of the traces had been cut. I rejoined it with kynar wire and now I have the saucer sound back.
woo hoo!
Kaizen088
130CR
Nice fix, it's always a good idea to check the quality of previous repairs.
Without the right tools and experience it's easy to lift tracks and pull vias out.
I'm working on a Nichibutsu Moon Base (Taito 3 Layer Clone) and the size of the pins on the ROM sockets are so close to the through hole size (add to that the pins are round) that it makes it very difficult to clear the holes first time, every time.
I wiggle each pin with a fingernail to make sure they are free.Kaizen0882018-08-03 01:19:06
RGP
Meeter & Greeter
2,039CR
I'll add to this that i've experienced a lot of SI boards sent to me with missig saucer sound are the result of bad ground traces to the 76477 chip.
Its a weird programmable sound generator that needs certain pins connecting to ground in order for the internal oscillator to work.
My bench loom had this problem originally as I tend to not wire up absolutely everything when making a loom.
Chased a missing saucer sound for a good day.
If I heated up one of the pins the sound would be there but when it cooled down it would go.
Decided to soak test a board in a cab and the saicer sound was there from cold.
Bit of an anecdote to say well done, good fix but useful knowledge.
