Space Invaders Part 2
VectorGlow
34 (100%)
900CR
BaldiGit said:
I've found one broken disc cap on the middle board, but they don't in any way match the Taito schematics. So don't know where to go now.....!!!!
To your nearest arcade board repairer.
Unless you want to jump in at the deep end and repair it yourself of course. What arcade board diagnostic and repair experience do you have?
What basic diagnostic equipment do you have? 'Scope? Logic probe? Logic pulser? Fluke 91910A with 8080 pod? Multimeter?
Are you okay with reading schematics?
If you want to use this as a pure learning excercise then go for it - my first board repair attempt nearly 20 years ago was an Asteroids board ........ but it wasn't really, it was a Lunar Lander board converted to Asteroids and was a real mess of mods and hacks. I failed. In the early days I found Galaxian boards much easier to fix so I did a lot of them and slowly branched out. Now I repair all manner of boards. It's fun (most of the time).
VectorGlow2018-10-20 19:26:46
BaldiGit
10CR
That is sounding our best option at the moment. I'm out of my depth with this, I'll have a chat with my friend and get back to you.
It's a shame really as he wanted an authentic machine. Although he's mad on most arcade games, he wanted this to be an original dedicated Space Invaders machine. I can see now the top add on board is probably part of it instead of an add on hi score or extra games board. He wanted it removed when we thought it an add on, as it wasn't original.
VectorGlow
34 (100%)
900CR
Remember that I'm not the only arcade board repairer here, "other repairers are available".
If you really do want to use an original SI Part II boardset then put up a Wanted in the Wanted section here, or keep an eye on Ebay. You may find a fully working one, if you find a faulty one then it could probably be repaired.
VectorGlow2018-10-20 20:14:05
BaldiGit
10CR
You might not be the only one..... But your the only one that replied so far
I'll stick a Wanted message up just in case there's someone out there with one. But not had chance to chat with my friend yet.
On a totally separate topic.... And as your an experienced pcb repair man. Are the Capcom CPS1 A boards repairable at all? As I understand it once the custom chip has gone south, their just a pretty door stop?
VectorGlow
34 (100%)
900CR
I just wanted to point out that I wasn't the only repairer as I don't want you or others to think I'm just jumping in to try and make some money.
CPS1 'A' boards - something of a nightmare. The custom chip is a common point of failure, replacements can only be found on other CPS1 'A' boards and also CPS2 'A' boards. It's often best just to try and find a working 'A' board, but they are getting harder to find as others give up the ghost.
Besides that, if the fault lies elsewhere (often RAM faults) the 'B' board needs to be in place for proper diagnostics to take place and the presence of the 'B' board obscures most of the 'A' board, meaning that diagnostics need to take place on the solder side of the 'A' board. And that is far from ideal.
Most, if not all, repairers who I've read about tend not to like working on CPS1 'A' boards. I generally refuse these days unless it's something obvious or a sound fault (another common point of failure is the Z80 CPU used for the sound, but at least this is far easier to diagnose).
There is a diagnostic program for RAM testing - two versions, but limited to Rockman and B-21 C board setups only.
BaldiGit
10CR
I have 2 boards, both with Street fighter 2 b/c boards. A world warrior (genuine) and a Champions edition (bootleg B board). One A board is dead to the world and the other has just started giving sprite corruptions. I don't use the boards, but keep them for my machine in case the next person who has it wants to have it as a dedicated machine again. My machine with the switching of a few plugs will go back to a dedicated cab you see.
I'll probably keep them as is I suppose. The working one decided to go iffy while stored. So there's probably no point in repairing it at the moment. I was just curious to see if anyone had reverse engineered the custom chip...
VectorGlow
34 (100%)
900CR
Reverse engineering the CPS-A-01 - I've read that somebody is doing that, no idea of progress though. Then there's the issue of manufacturing a custom (very expensive) or using a CPLD or similar. THEN you need to figure out how to mount any replacement (it's a surface mounted). I'm not that familiar with all the processes involved, having never designed or reverse engineered a chip in my life.
For more info on the 'A' board custom have a look here:
http://arcadehacker.blogspot.com/2015/04/capcom-cps1-part-1.html
https://forums.arcade-museum.com/showthread.php?t=418776
