Space Invaders RGB+SYNC Mod?
RGP
Meeter & Greeter
2,039CR
Do you know if anyone posted documentation properly for getting the video and sync separated for running on a test bench/JAMMA rig.
I have 2 L-Shaped Midway boards.
One has a couple of wires going to pins J and K from two resistors which match VIDEO and SYNC just before they get combined - there's no trace coming from those two pins at the edge connector - they live up to the spec of "no connection".
However, the other board has those two pins specifically pulled to a ground plane.
The manual suggests that they're not used so i'm thinking its ok to probably just cut the trace and jumper wire like the other board.
LukeWells originally did the mod on the first board, i'm just trying to fix up another and make it convenient than dragging a composite monitor in.
Judder
1,009CR
Picture at the very bottom of this thread should help I think (it's before the sync is combined if I remember reading correctly)
http://www.ukvac.com/forum/space-invaders-using-a-19-tv-as-monitor_topic339495.html
Judder2017-04-12 12:20:11
RGP
Meeter & Greeter
2,039CR
Cheers mate, that helped a lot.
I did some trace work and found that although they've laid out a trace from J,K to a pin to the interconnect between the two boards, it goes absolutely nowhere else.
Only thing I can think of is they planned to do something and then changed their mind.
So I cut the traces to give me two pins.
Maybe its implemented on another game like Sea Wolf.
After that I was able to find VIDEO which is at pin 13 of C3 and Sync was not far away from that and ran jumper wires to the edge connector and now have this board modded.
I should really make a better loom up which uses comp and run an extra wire to my monitor's back panel.
I've done a video of this board repair which i'll edit and post later in repair logs.
Thanks again :)
