Space Invaders Rolling Screen
Stickman
355CR
So I have spent many hours fault finding my Taito SI I picked up and I have a fully working game board from what I can tell.
Whilst going through the repair I was using the test rom (what a great idea!) and I suddenly started getting the screen just scrolling.
The chassis has been recapped and I also checked the pots on the chassis and they all seem ok. No matter how hard I try I can never get it to lock in, it is the Hfreq pot that I have to adjust, it gets close but just starts going the other way. Strangely when using the test rom I can get a stable screen albeit a bit wobbly. I have checked the board and cannot see an issue and swapped out the 74LS55 at A6 and also the 74LS04 at A7 with no change after doing some googling.
I have tried to identify the chassis to get a set of schematics so I can at least work my way through the chassis to see if something has just given up, maybe a crappy cap I put in. I reflowed the chassis as well.
Any help appreciated, I will try and see if I can get the board in another machine to isolate board or chassis.
Stickman2022-03-29 16:48:34
Stickman
355CR
The video is composite so it is either a board issue or chassis but I am being drawn to the chassis at the moment as it rolls horizontal and vertical but I can often dial vertical in. Initial checks of the pot suggest it is ok, having found a schematic for the chassis (cheers Purity) there is a HA11244 IC that is controlling this as well and the fact it just suddenly went maybe it’s that, one on order so let’s see.
Stickman
355CR
no been trying to find something and you saying hand held I just remembered I have one on these silly little multi game things that is composite output. On my way to the garage now to try it
Stickman
355CR
well thanks for that cracking idea, defo chassis issue as same problem, had a bit of Sonic the hedgehog on the screen and not able to dial in the H Freq to hold it still
Stickman2022-03-30 20:28:18
RaveN
1,325CR
The Toei chassis's are bulletproof. You'll have no issues at all with them apart from the electrolytic caps. The main one (on a separate shield?) needs replacing, and there's a few tiny ones near the input (from memory) that are more prone to leaking.
The variable resistors are cheap and primitive, but seem to last.
Stickman
355CR
So this continued to vex me, so I reached out to the guru that is Randy Fromm. All I can say is what a great guy, so helpful and gave up an hour of his time (as well as emails) to do a 1 hour video call with me whilst we worked through the chassis with the scope.
So the issue was sitting with the sync circuit of the Toei GM20 chassis, we could see an issue on the output of Q4 not giving a decent sync pulse that was stripped from the composite video signal.
So rather than shot gunning which was the route I was taking having changed Q4 & Q5 (recap was done as standard when I got t), H. Freq Pot and starting to check pretty much every component I focused around Q4, lifted one end of the four resistors R20,R21,R22 & R23 all connected to the emitter, collector and base.
Well would you believe it R20 (390k) was open circuit.
Replaced this and have full sync back so happy days.
Learned a lot about composite video and sync and cannot stress what a great guy Randy is.
