Space Invaders (Taito)
Danscu
257CR
Hi
I bought a nice Space Invaders upright from GrantB back in July and Martin dropped it off here on Tuesday.
Unfortunately nothing comes on when powered up, apart from the marquee light:(
Its my first SI (and most expensive cab!) so I wanted to ask for advice and hopefully get this running!
Dan
Grantb
11CR
Hi Dan. This was working perfectly when it left here and the pcb gone over by mark at retro clinic not too long back.
I'd say something has come loose in transport. Have you had a look to see if you have power inside? Can't remember if it has a back door switch?
Danscu
257CR
Thanks guys, I will do as you all suggest and report back. Grant, its in lovely condition and I am very pleased with it, dont worry I'm sure it will be something simple, just that I have no experience of this cab
Equites
Chief Sheesher®
35 (100%)
3,329CR
Grantb said:
I'm sure it will be something easy. It's been well looked after. Anything I can do to help, just let me know
Not necessarily, I’ve had NOS components in a drawer in anti-static tubes go bad. It’s just the nature of the beast.
RaveN
1,325CR
Narrow it down.
- Do you see a glow from the neck of the monitor?
- Do you hear a sound the moment you turn it on?
- Are the fuses (4?) intact?
Danscu
257CR
Hi guys, I have only just had a chance to tackle this follow your advice, fuses all ok, checked voltages, checked all connectors and I think that was the issue as it is now running perfectly
Many thanks all!
