Speaker issue on Jamma
neoretro
1,121CR
Hi All,
Trying to get an electrocoin Xenon back to its big beautiful best.
The right speaker has never worked since I’ve had it. Opened it up and the left speaker is wired to 10 and L on the Jamma Loom and works.
The right speaker is however wired to 11 and M. There was a broken cable and some loose crimps but sorted those. Still no sound. 11/M is not connected on standard Jamma.
What’s the likely reason for the speakers being wired there, and what’s the fix for this? Chain them so they go back to mono? Or is this a stereo mod gone bad?
Thanks for any help.
Dave
neoretro
1,121CR
There’s a couple of cables coming off the body of the speaker disappearing to down near the power supply. I assume that was earthing.
MVS wiring requires a ground doesn’t it?
LHantz
9 (100%)
327CR
With my Xenon, for Stereo I connect the R speaker directly to the PCB via the Stereo connector, some use the JAMMA connector as the L channel. your Red terminal (+) should be marked under the Male spade connector on the Speaker in your Xenon.
I have not seen Stereo through a JAMMA harness, my cab is wired the same as yours. Heard about MVS through the JAMMA connector, not tried it though
LHantz2019-04-04 00:05:51
neoretro
1,121CR
This is exactly what I can see with the red marked spade.
What sort of voltages do you get through the speaker cable? Will check them later?
bomjac
453CR
http://www.swallowam.co.uk/jamma.php.
Seems that the electrocoin standard uses L&M, N&R for the 2 speakers. Jamma as standard used 10 & L for the speaker, 11 & M for "pre-amp" for external driven speakers.
Electrocoin based their standard on the original "Universal" connections like Mr Do. These games had an external amp for the speaker output to the cab.
bomjac
453CR
Electocoin's was "Unigame" - that was their standard marquee. Based on the Universal pinout, but possibly it evolved to stereo as games progressed. Mr Do for example originals had a seperate amp for sound.
neoretro
1,121CR
This would make sense if it wasn’t that the left speaker works and with electro coin standard that means my left speaker is wired to Speaker 1 and Meter 1.
5,415CR
one of the labels inside a Electrocoin I had showed wiring for those little electrocoin amps also used in fruit machines which would probably of been connected to the where your Right speaker is connected so depending what board is fitted, it would use either or speaker with amp or without
It depends what games you are going to play in there, as you've said the Jamma connector only has one speaker connected, and most older games only have one output. the later games with stereo you will have to connect to other connections on the pcb.
I was thinking about fitting amplifier in my cabs, so instead of having games like MR Do with separate amp which you then have to store with pcb, make jamma connector up so that game goes through the cab amplifier, will take some extra work but could be done, also if that's right on Jamma pinout the low lever audio out is on 11/M you could have amplifier connect to those, then have volume control inside coin door like dedicated cabs so you can adjust without altering pcb vol pots.
Then you have the ones with Stereo output, you want to make use of it if you can, some have separate outputs like Street Figher 1, that was wired for stereo sound in the Electrocoin Cab but iirc it was on separate 3or4 pin plug, so when I connect standard Jamma in that cab you get no sound
Good thing with having the Unigame connector and then Jamma adaptor to that, it gives you more options to connect all this up as you can wire extra connectors up to the unigame one for stereo sound, but your standard jamma ones will still work as well as that can be connected as standard, very flexible
What game have you been trying it on? has it got stereo sound?
neoretro
1,121CR
Just checked the speaker. 8 ohms but only across 2 of the 4 tabs available so may have to check that.
Getting a circuit to the connections.
Regarding what boards I’m using, I’ve been using a Pandora’s box but about to check a Sunset riders board. Am wondering whether the Pandora’s box doesn’t give stereo/two speakers off the Jamma edge.
Been using that as it’s my first time trying to fix up a machine and didn’t want a decent board in there in case I do something stupid.
neoretro
1,121CR
I’ve just found the wiring diagram and it agrees with this. Thanks.
Bit of a problem, no amp.
What’s the best/simplest fix from here?
