Spinners
strykr
1,351CR
DanP said:
Hi guys, anyone ever used one of these in a MAME setup?
http://www.ebay.co.uk/itm/RED-ARCADE-SPINNER-USB2-0-LARGE-FLYWEIGHT-/370494579766?pt=UK_Video_Games_Coin_Operated_MJ&hash=item564332a436#ht_2675wt_1374
Like to know if they are any good before shelling out, they aint cheap.
Dan
Havent used one of those, i've got one of these in one of my cabs and it works a treat,
http://groovygamegear.com/webstore/index.php?main_page=product_info&products_id=268
mounts in a standard button hole, fired up mame and next to no config needed. its not very weighty though, dont know if that matters to you?
I imagine there pretty much the same deal,
Vid review here.
http://www.youtube.com/watch?v=F_XfJ4bSnCo
strykr2012-08-13 22:51:26
minwah
238CR
I haven't used one, but it's an Ultimarc SpinTrak and are widely well reviewed.
You should be able to say a few quid by buying directly from Ultimarc. I've just ordered one actually...
www.ultimarc.com
DanP
Administrator
2,232CR
I bought a pair of these in the end and they're pretty good, certainly good enough for me. In the end I got them with the heavy flyweight, not sure how they would be with the light weight one.
Dan
Danscu
253CR
I think they are great as well. I've got a couple with the the mini steering wheels that install on them for driving games such as Championship Sprint, so they make the spinners dual purpose
strykr
1,351CR
Dan
Which ones did you get in the end Dan? the ggg ones or the ultimarc?
DanP
Administrator
2,232CR
I got the one in my eBay link. I think they are more expensive now too, pretty sure they were £60ish when I got em.
strykr
1,351CR
Gotcha, cheers
Im happy with my ggg one, would love to add the flyweight but not enough room under my CP. its still very good for a bit of cheeky arkanoid every now and then :)
strykr
1,351CR
virtvic said:
Maybe someone could make you a weight for your spinner?
Its called an "energy storage cylinder" on the website,
Can
be used with or without an optional rotational energy storage
cylinder. Gives you a choice of near-zero "moment of inertia" or prolonged
spin! Note: The ESC geometry has been designed and extensively playtested to provide excellent performance across all gaming genres. It does not
hamper control through the excessive moment-of-inertia requirements
that are often associated with spinners claiming "long spin times."
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=86&products_id=268
What do you think Vic?
ive only got clearance for the metal that protrudes at the bottom. probably about 6-7ml
Danscu
253CR
I'm in a similar boat but need a smaller diameter disc due to controls at the sides, but have plenty of clearance at the base as the CP is quite tall.
