SR2 model 3 - PC converison
Kev A
747CR
Sad to have to do this, but started up my SR2 the other day, only to find it had developed graphics glitches, narrowed it down to the video board, not a problem I thought, swapped out for my spare stack which was working 100% when I stored it in the house, only to discover that too had died in its sleep, again narrowed down to the video board :-(
I had already tried to safeguard the boards by replacing the PSU for one from a Naomi, check voltages regularly and move PCB's indoors in cold weather, but still lost three video boards, and given the cost of them have to draw the line somewhere.
Good news is looking online, progress seems to have been made with interfacing the FFB with a pc, but much of the info seems to be on the French Gameoover site, and reading with Google translate, is a bit of a mission.
Anyone here converted a Model 3 cab to PC recently? would welcome any advice as I'm fairly new to emulation.
Would like some sort of self contained PC within the cage, so I don't have to mess with any of the wiring, If I could get it running with SR2 I would be happy, but being able to play other M3 games would be a bonus.
Im a bit confused with the following areas.....
24khz, I know this can be used with special drivers, but what happens during boot up, perhaps use a Jpac to filter out any signals that could damage the screen?
Frontend, any easy to use, that can be used for Model 3 emu in 24khz?
Graphics cards, think it needs to be ATI, which ones would be decent enough to play M3 games but small enough to fit within the original cage?
Also how does the software pick the FFB commands out of the game? Much of this info is in Gameoover and in various GitHub repositories, but if anyone has already done it and give me some pointers that would be ace, as I think otherwise its going to be a lot of trial and error.
Sbdesign
SEGA collector
16 (100%)
1,721CR
1 FOR SALE IN THE PAST
this guy sold one, I was tempted at the time. But linking because he maybe able to help if he did the build.
In a advert stuff listed as...
This "NEW" Devices are build in the PC:
I5 4670 CPU ------ (£50 ebay)
Gigabyte H97M-D3H ------ (£59 ebay)
Gigabyte GTX750ti Low Profile------- (£50 ebay)
Be quiet 300w TFX PSU
4 GB Ram
SSD Disc
Model 3 Filter Board with Mod.
Model 3 Case
With a other GFX Card (Like ATI Radeon HD7750, low Profile) and in combination with CRT Emudriver it is also possible to play these Games on the original 24khz Monitor in authentic Resolution,
31 khz (VGA) is also with the GTX750ti possible. For higher Resolutions -> 720p the GTX750ti is the better choice.
So only about £200 -£250 to buld
Now I wonder how much better it looks running at 31khz, and use some naomi monitors
Up scaling 3d graphics, do look good.
Sbdesign2020-08-29 13:31:53
devtty0
222CR
I’ve got a sr2 that has graphics glitches that I’m just living with for now - but would def consider a pc conversion if it could be done without butchery.
Got any links to the french pages? Or what is the mod for the filter board?
tb2000
3,583CR
I've always thought that should I ever pick up a model 2 or model 3 cab (or a twin) with graphics faults or boards not working, i'd almost certainly do this pc conversion. Like most people I always prefer to keep stuff original but in this case I think if it can be done with no hacking then it's a good solution that should be a sight more reliable than the original boards.
jinq-sea
237CR
I think lots of the Model 3 info has been a bit of a closely guarded secret - I'm certainly interested in it though. I've a PC and a Model 3 cage crying out for the PC to go in it!
ZedEx48K
8-Bit
1,425CR
I remember SailorSat hooking up FFB all through proper connections and the filter board etc, and a machine/PC has been sold on here with the same design too, however I never heard of the info being shared.
The PC side of your conversion is a piece of piss, but as you know it's trying to hook up the original controls that is the hunt for info.
Kev A
747CR
That's a good point SB, If I buy the same kit the German chap was using, then it should all work, in theory anyway :)
Yeah I always prefer original over emu, but I really cant justify spending any more.
This is the thread I was reading, in short looks like its the M2pac, developed by BigPanik a few years ago, with extra work done by another chap to make it compatible with more games, in the last few posts he specifically mentions SR2.
https://www.gamoover.net/Forums/index.php?PHPSESSID=8l846ooeljit8ejplhgfgdmuk3&topic=42082.112
tb2000
3,583CR
devtty0 said:
So first step - get a m2pac.
Does the French dude sell these? Or are there schematics?
Actually - good docs here : Gameoover
Looking at that post it seems like it's not too bad to sort out. Really worth doing if it's all fairly easy to obtain bits, especially when you can ply other model 2 and model 3 (and any other driving games I suppose!) games on it as well.
Kev A
747CR
Yeah I think in a very simplified version, the M2pac is just what BigPanik was calling his Arduino solution, it should all still be available, as it was just off the shelf stuff, with his software.
When I last looked at it a year or so ago, the M2pac would work with Model 3, except there was no translation with the FFB, basically the Arduino just sent whatever the game outputted to the FFB drive board, so you had to have the FFB rom that matched the game you were playing, but this other dude now has magic code that translates the FFB commands.
Its a shame there's no step by step guide, it seems like all the info is out there, but scattered about and mainly in French, but I'm up for giving it a go, perhaps if a couple of us were to try at the same time, it may be easier, as we could share info as we go. Im not interested in having 100s of games, and wouldn't even be too worried about flashing buttons, as long as I could get SR2 playing on the CRT with FFB I would be more than happy.
Vamino
Insert coin(s)
2,700CR
Model 2 and Model 3 use a different dashes which use different generations of FFB boards.
M2PAC/L2M2 will not give FFB on Model 3 dashes, that solution only gives FFB on dashes from Sega Rally 1/Daytona etc.
The guy who sold the M3 PC is using a different method using bespoke software not widely released, then the output is somehow wired directly to the Model 3 filterboard so you can plug it straight into a cab like Sega Rally 2. So even if you bought the same PC components you are kinda stuck with no FFB as the info is not out there.
It would be nice if the info had been released, but Frank and Sailorsat have their reasons I guess.
There is another option though, but it's not cheap.
Info is in here on page 13: https://translate.googleusercontent.com/translate_c?depth=2&hl=en&prev=search&rurl=translate.google.com&sl=fr&sp=nmt4&u=www.gamoover.net/Forums/index.php%3FPHPSESSID%3Di0jrga9iejkt0dcfsgg4vetdi5%26topic%3D21154.0&usg=ALkJrhiIf9luOp880L1Vwrphkllk03LqVw
SimuCube + IONI + power supply is what I'll be doing once I have an LCD cab sorted. As far as I can understand this setup can basically turn any motor into a FFB device for PC.
Kev A
747CR
Yeah that's the way I always understood it, the L2M2 will never work with Model3 boards, and likewise for many years the M2pac couldn't either, but this other guy seems (If I understand it correctly) to have expanded the capabilities, and added translation, to make it work with the M3 FFB, and most importantly he has his released it onto GitHub.
Kev A
747CR
Yeah that bit does worry me, although in the forum he states that he has tested with an SR2 ffb rom and it works, so hopefully the readme is out of date, guess there is only one way to find out :)
Vamino
Insert coin(s)
2,700CR
Never realised this was a thing, gonna have a read of that later.
I've got the bits for the M2PAC somewhere but never got around to tinkering with it.
Thanks.
Kev A
747CR
No probs its a very recent development by the looks of it, its only because my boards were playing up I had a look online and found it, I could be wrong but it does look like its now possible, I hope so anyway :)
