darthsylly
Does anyone have a good recommendation for an 8-bit SRAM tester that's easy to get hold of in the UK?
tb2000 said:The Wellon series of eprom programmers (apart from the vp-290) can test ram (and ttl).
No RAM testing for vp-290.VectorGlow said:tb2000 said:The Wellon series of eprom programmers (apart from the vp-290) can test ram (and ttl).
Do they now test 2114 RAMs? My VP-280 used to then they removed that support from the software and haven't added it back in.
I wasn't aware they'd removed it! My software is 4.3.4 which I thought was the last proper release for the VP-280. It comes up with the Hitachi 2114 as the only variant, but it still works - you just need to bridge the vcc pin to the next one up the socket. Presumably it needs higher voltage so needs to be connected to two pins in the zif socket for it. How reliable the test is I don't know, but I just tested a known good Nec 2114 on mine and it said it was ok.VectorGlow said:tb2000 said:The Wellon series of eprom programmers (apart from the vp-290) can test ram (and ttl).
