Star Force bootleg graphics issue
Lurch666
21 (100%)
4,517CR
Got this two board starforce bootleg running by replacing some CPU ram and you can just make out that it's showing the crosshash pattern before going into it's demo mode but all the graphics are bad.
Checked all the ram and eproms.
Not sure if it's bad data coming from the CPU board or the video board corrupting the output.
Game doesn't play-I can put a credit in but it doesn't appear to play it just goes back to demo.
Fantazia2
2,246CR
I had a faulty one a few years ago that I sold on here, the buyer got it working but said there was loads of crap fujitsu logic chips on it that needed replacing as they are a bit crap, might be a direction to look in to.
Lurch666
21 (100%)
4,517CR
Checked all ram on both PCBs and swapped some ram on video PCB.
I think it might be an addressing issue as well but can't find any missing.
All the eproms have active address/data lines and all the buffer chips appear to be working. It could be the address info is getting corrupted before it reaches the video PCB but I can't figure out where since the address data is present and I have no way of seeing if it's incorrect.
sukhbir
46 (100%)
1,735CR
Have you checked the activity on OE,CS,WE inputs to the video rams?if correct then i reckon its might be those nasty fujitsu chips causing bad inputs.
Lurch666
21 (100%)
4,517CR
All the fujitus checked out (surprising) so I started looking at the buffers for the main CPU.
I was looking for LS245 or LS244 but it turns out it's using LS367 for some of the CPU buffers.
The first one I checked showed a bad output on one of the pins and a piggy back showed an improvement in the graphics so tomorrow morning I'll check the other LS367s,swap out any bad ones and see where that gets me but it does look like I'm onto something here.
Lurch666
21 (100%)
4,517CR
That did it.
Replaced the LS367 at N4 and the graphics are all good now.
Controls work but sound doesn't so will just have to sort that out and this one will be fully working.
sukhbir
46 (100%)
1,735CR
Great progress
