Star Wars yoke controller
RetroDan16
3CR
Hello all,
I've just (yesterday) managed to get hold of an original Star Wars yoke controller, which was given to me very kindly with the caveat that it was broken.
After a look, the small 14 tooth gear wheel has perished as it was fractured.
I've seen some 3d printed reproductions on eBay, and wondered if anyone had any experience of them and if they are any good etc. Or, if there are any alternatives that could be suggested.
My second question is, (and this is a long term project but I am trying to plan for when I do get it going) what's the best interface to make a USB connection? I'm reading about u-hid boards and a-pac boards and all sorts, and I'm not sure what the best/easiest solution would be.
Any advice would be wonderful, thank-you!
Stevros
506CR
are you mameing a star wars cab?
Jodo
Boy is this a machine!
607CR
I used one of the 3D printed ones temporarily until I found an original replacement and it was fine; it comes with a tiny set screw that is fiddly but entirely possible to fit but don't over tighten it
RetroDan16
3CR
Good Lord no! I just have a yoke which I'll make a removable mount on my existing Mame cab. Absolutely nothing will be butchered or modified other than the connection from the yoke to the machine (as in removing the plug from the end!)
I'm a preservationist, not a butcher!
If I had a Star Wars cab, I would NOT be MAMEing it up!
RetroDan16
3CR
Bearing (!) in mind it's not going to have heavy use and abuse, I was thinking that a repro would be fine. It's not going to be under heavy stress or abuse on a regular basis at least.
Thanks!
stevebm1
39 (100%)
1,274CR
you don't touch the pots in the original yoke,you just run the wires from the yoke to the gamepad pcb,there are photo's on the web showing you how to do it
RetroDan16
3CR
Just found the guide, looks like a cheap and relatively easy way of doing it thanks! Just got to get that gear replaced now and a Dual Strike.
Thanks for your help!
ColinD
6 (86%)
1,367CR
If you know anyone with a lathe, you can buy a metal gear off the shelf for fiver or so and have it modified to make a good repro...
In fact... HPC gears prolly have one in stock and will modify for under £10 to do the grub screw and bore out to the right size (and cut down if required). Not difficult at all.....
I'm sure if you sent them the old gear and the picture below, asking them to copy it ,but stating its not mission critical and just needs to be as close as possible using a modified stock (hence low cost) part, you would be looking at £25 delivered or there abouts for a one off (maybe a lot less) but postage will be the killer here, lol.... 10 minute job for them at most !! - Get 5 made and sell the rest at 1/4 of the whole price, giving you a free gear !!
Looking at the Catalogue and *guessing here* at a Mod 1 Heavy Duty Spur Gear with a longer boss its £12 plus the mods to cut down / bore , grub screw etc which are cheap..... couple of quid per operation.... They will be able to advise.... if you are really tight, you may find that you can settle for a wider boss (or longer boss or teeth face etc) saving on modifications, but still having a part that fits nicely without clashing with other parts like the springs, iirc it just sits on the pot out of the way anyway.... get the ruler out and see......
This one came from Farnell years ago and had it tweaked..... works fine... easy peasy stuff.... Farnell iirc use a different supplier which are cheaper. *but* they cost a LOT for mods, hence why I say use HPC gears ;-)
on this one teeth are 9mm deep, with a 5mm boss, 14mm total, boss o/d looks about 12mm and the bore just over 6mm.... a little bit of grease on it and it will last for ever !!!
once you start looking, parts will jump out at you that can be modified easily to match..... ;-)
ColinD2014-10-24 20:45:37
ColinD
6 (86%)
1,367CR
You can probably use an XG gear £8.76 (15mm deep) and have about 6mm of the teeth turned off to make/create the boss at the correct diameter size (you probably might get away without doing this!!)..... and then have it bored out (they are 6mm as standard) and drilled / tapped for the grub screw !! (this is assuming its a 1 MOD though - check first !!) - SO mods would be £7 plus whatever they charge to face the gears off to make the boss..... (as above you might not even need to do this and just have the grub screw drilled/tapped inside the gear teeth with no boss / reduction, so the whole body is just a big gear with no boss and a tactically placed grub screw if that makes sense ??)
Thats cheap enough to take a punt on :) I don't think you will have any issues here.......
ColinD2014-10-24 21:16:07
ColinD
6 (86%)
1,367CR
Looking like something like this on the back of an envelope.... NOT TO SCALE, LOL
I reckon that will fit near perfectly but check the grub screw position first... ;-) Looks like a 3mm grub screw and if you ask them nicely, they might supply one too......
So around £16 plus postage + Vat.... Job done ;-)
ColinD2014-10-24 21:45:10
RetroDan16
3CR
Thank-you SO much, this is great! Where I work there's a fully fitted toolroom with all manner of lathes, etc so I could get any alterations done. I'd never considered a hard wearing metal one like this, so this is awesome. Thanks matey!
ColinD
6 (86%)
1,367CR
No Problem.... Like I say though, HPC gears will make them cheap without you owing any one any favors..... Post some pictures of your progress.....
Cutting Gears is an art, so its best to just use an off the shelf part that is oversized, and then sculpt it down ;-) HPC do this day in day out....
If you want to go the diy route, look in Farnell at the gears (if they still have them ?) and you might find the one I used above...... as I say, very easy to modify.... I had an Outrun Gear B *variant* (not exactly the same dimensions to save costs) done at HPC cheaply and it was very nice :)
ColinD2014-10-24 21:59:29
RetroDan16
3CR
I get ya - I will talk to the guys in the toolroom as they're usually very helpful and love working on a foreign job lol. I've managed to get the total dimensions of the wheel, if anyone needs them for their own projects, I can always post them up if useful.
I'll keep you updated on my progress!
ColinD
6 (86%)
1,367CR
When 'nipping' up the grub screw, ensure that the pot is 'exactly' midway and that the yoke is centered nicely ( in the game it should say 80h iirc), otherwise you could strip the other gear if you reach the end points on the pot before they hit the mechanical end of travel of the controller ;-)
RetroDan16
3CR
Can you see the pot turn? Or, I mean, what's the easiest way to tell it's centered? I haven't delved too deep into it yet you see :)
obcd
3,830CR
You can measure the pot ohmic value. If it's a 5K pot, you should have 2.5K between both the outer pin's and the middle pin of the potmeter. Between the 2 outer pins you should measure 5K
Before you do that, disconnect the potmeters from wathever they are connected 2.
