Star Wars
DanP
Administrator
2,173CR
Symptom: Some odd
graphics during gameplay. Scale test
fails with one side of the square box detaching from the box.
Action: Looked for
broken links/components on AVG board.
Found .01k Cap at C2 had a broken leg.
Fix: Replaced cap
at C2.
DanP
Administrator
2,173CR
Symptom: Vectors are there but screwy
Action: Swapped in another known good AVG board
Fix: AVG board was bad, need to fix now...
DanP
Administrator
2,173CR
Symptom: No TIE fighters. All other objects visible. When you reach the Death Star the game hangs.
Fix: Bad mathbox PROM @ 7K on the main PCB. Re-blowing a new PROM fixes the problem.
DanP
Administrator
2,173CR
Symptom: First phase of the TIE fighters is OK. When you reach the Death Star the game pulses on and off causing the spot killer to kick in.
Fix: Bad address controller gat array @ 2J on the AVG board. Replacing the IC cured the problem.
DanP
Administrator
2,173CR
Symptoms: Intermittent sound board resets during game play. Choppy / incorrect sounds.
Fix: +5dc voltage was +4.68dc at the AR 2 board. As a result around +4.5 was getting to the sound logic after wiring / interconnect drops. Adjusted AR 2 board to 5.10 to cover the drops. This allowed 5.05 at the chips. No more problem.
