Step down converter problems
Body pop
24 (100%)
1,266CR
My qbert has recently melted the step down converter that came with it
I got a loan of another and done the arcade shop power supply mod
It worked for an hour or so and it appears that the step down converter has gone again
Has anyone ,any idea why it would be doing this
Flinnster
The Dino King
29 (100%)
2,566CR
Yowzers. Is the wattage rating just because it's a classic age cab and has the solenoid then?
I presume more modern / candy cabs aren't rated 300w!
forcefulfil
EDOT King
17 (100%)
1,675CR
Has the light ballast been changed?
My tron ate step down transformers until the light ballasts were swapped.
I know the wattage has to be a certain threshold.but I'd check.
Body pop
24 (100%)
1,266CR
I’ll have a look at that also ,I assume there’s just the one In the marquee in qbert
I don’t think the marquee works at the min
Body pop
24 (100%)
1,266CR
J69 said:
https://www.arcade-projects.com/forums/index.php?thread/5051-how-much-watt-does-a-crt-cab-use/
These guys are running step down converts costing about 250
I’m hoping I don’t need anything as fancy as that !
Body pop
24 (100%)
1,266CR
I assume that black bit is the ballast ?
It doesn’t look like it’s been changed ,if I disconnect the marquee ,will that be taken completely out if he equation
My new step down converter arrived today and don’t want to wreck it
Also since fitting the arcade shop power mod ,the sounds are weak ,what voltage do these need
It’s set at 5.05 v at the min
