Super Cobra
jonhughes
1,156CR
Hi everyone,
I have a Super Cobra PCB that I bought a while ago. I don't know much about them but have read that they require a 'black box' to operate. I have no inclination on what this 'black box' does or whether it is required for this particular PCB. There is a high score save kit for sale in the U.S. that claims to remove the need for the 'black box'. I have the correct Konami adapter for it that is fully working with my Scramble PCB. Can anyone point me in the right direction - without knowing if I need or have the correct hardware for this PCB I can't really do much with it. Should it be displaying something without the 'black box'?
Jon
jonhughes
1,156CR
I'm missing something. This is a picture from the web site. I'm presuming the black box is the thing on the left, but I can't see where the wiring from it would go to on my board - there are no empty sockets and my board looks the same as that particular one.
sukhbir
46 (100%)
1,734CR
hi,looking at your super cobra pcb you have got the stern version hence the name stamped on the eproms.the jap release of this game only had this black box and its grey ribbon connector is fitted onto where the z80a cpu is normally fitted on the bottom pcb and the power connector is the two pin plug on the top pcb corner.plug in your scramble adaptor to the pcb and power on you never know it may work.
jonhughes
1,156CR
Thanks, but already done that. Looks like it is a problem else where.
jonhughes
1,156CR
Belike said:
I have  a Konami version, it works fine without any black box with the Konami/jamma adapter.
Thanks, the game is outputting a series of red and white rapidly fluctuating lines, as shown. Is my connector right - do I need to supply +5v & GND to the two pins above the connector, in the photo.
4,058CR
That appears to be a Sync issue with the PCB. Do you know for sure that other PCBs have worked with that 'Supergun' and monitor? If it were an arcade monitor then the first thing to do would be to try adjusting the horizontal sync, but given it's a TV I don't know if you'll be able to.
jonhughes
1,156CR
Hi, it works fine with my scramble PCB. This screen doesn't last. I've found out that it cuts out to dead after about 30 or 40 seconds. The voltages are down to about 4.8V at the back of the lower board.jonhughes2014-01-07 13:35:16
sukhbir
46 (100%)
1,734CR
that connector is only used for the black box,looking at the picture it looks like the cpu has crashed,take the z80a cpu (bottom pcb)out from its socket and clean the pins and retest.if no luck then its time to get the scope and schematic out and fault find.good luck!
P-Man
International man of mystery
1,273CR
It looks like you have sync, but not a decent video ground, causing tearing of the scanlines in your photo (there's blue box there onscreen). check the video grounds to your tv, and join them to the power ground, and you might get a more legible screen of garbage. But it'll still need fixing after that :)
jonhughes
1,156CR
Thanks to everyone but I believe this particular project is beyond me. I just wanted to make sure I had the correct set up before throwing the towel in ('black boxes' and all). I've contacted a repairer who will hopefully cure this one for me.
