Sync Cleaner RAM questions
StirlingSteve
5CR
Hi all,
An old friend and fellow arcade fan recently gifted me a pair of Side Arms (bootleg) pcbs, both with what hopefully should be fixable problems. I've managed to get them both displaying stuff but sadly both are having sync issues with my rather basic test rig. Both boards synced fine before in my mate's JAMMA cab so it's most likely my LCD TV (ironically a Samsung SyncMaster) that can't cope.
I've done a bit of googling and came across this Sync Cleaner which sounds like it might help me out. Does anyone have any experience of devices like this and will it help me in my predicament? If so, is there anywhere in the UK I could pick one up from?
Secondly, I've traced a graphics issue on one of the boards to a dodgy RAM chip. It's a Toshiba TM2015BP-10 but I'm having trouble finding a reasonably priced direct replacement. Can anyone suggest anywhere I might be able to find one of these? The board does have "5813" printed under where the chip was so I thought maybe this might refer to an alternative chip but I don't seem to be able to find anything relating to that either.
Any advice is greatly appreciated :)
StirlingSteve
5CR
Ah yes I found that thread about 10 seconds after I posted! Doh.
It would no doubt do the job for me but I'm on a bit of a tight budget and it's probably a bit too clever for what I need, what with all these negative and positive and separate vertical and horizontal syncs and stuff :)
If I can't find anything cheaper I'll most likely go for this but will have to wait till next month.
Ta!
porchy
994CR
What vga converter are you using?
I struggle to get sync on some titles using one of those chinese GBS things.
Also, is your video ground hooked up?
StirlingSteve
5CR
Yeah my video ground is hooked up to the main ground. I don't have a vga converter, I just have a JAMMA loom which I've put a SCART connector on and that goes straight into the back of my TV.
Hurray Banana
2,760CR
Make sure you have some of the grounds on the scart connected, shield, audio ground and video grounds. It may be this.
StirlingSteve
5CR
Yep, all the video, audio, RGB and chassis grounds in the SCART are connected together and earthed to the board.
I don't own any fully working JAMMA boards to test my loom with yet but I took it to a friend's house to try and his board synced fine with it on his LCD TV. Also my dodgy Mortal Kombat gives a solid yellow screen with no sync wobble on my TV so I'm pretty sure it's the Side Arms boards giving out weird sync signals my TV can't handle rather than wiring issues with my loom.
Taz, I may well take you up on that offer if you think that box of tricks might help!
