Taito Space Invaders PCB photos
P-Man
International man of mystery
1,246CR
hi all.
I'm on a bit of a mission at the moment to answer numerous questions about Space Invaders and to hopefully provide a set of webpages that can definitively answer it all with evidence. In the future you can compare what you collect with what was released and then you can work out how original, and where in the chronology your own items sit.
Its an iconic game, but there are a _lot_ of pcb types and rom versions. The chronological order of all of these seems to be completely up in the air. Seeing as the game code differs between a lot of the versions, you're playing a different game essentially. I'd like to tie down versions once and for all and then see how the code was changed over time. A lot of 'repaired' pcb sets also have original roms removed, and a generic (mixed up set) is burned onto a single eprom. This is a false economy, single-rom converting a space invaders pcb is a total waste of time, and it detracts from the originality. I repair these for a living, and there is nothing unreliable about old eproms.
If you are an owner of a Taito Space Invaders machine or pcb, i would really appreciate a good photo of your pcbs. I'm primarily looking to be able to read the rom labels, pcb labels and pcb etching. If i can't make out what they are from your photo i'll be asking you questions about them :) knowing the serial numbero f your cabinet at the same time would be a help (a photo of the serial number plate would be ideal)
I have a lot of info on 3-layer sets, so my initial request for information will be for L-shape pcbs. If you own a Taito blue upright machine you should have the L-shape pcb set, i'm mainly interested in seeing the following :
- main pcb photo square on.
- daughterboard photo square on
- a photo of the serial number plate on the back of the cabinet
- a description of the paper pcb labels that you can see, and their numbers, as well as any etched numbers.
You can email me directly andy at andysarcade.net with your photos, i prefer to carry out communications by email rather than through a pm on here.
thanks, and hopefully you can help me fill in the picture!
tonyg64
22CR
Andy, could you post pics here of examples of the view you want from each board/ sticker etc? For those noobs like me we dont all necessarily know which components are which.
I'd be happy to post pics of my SI cab .
Tony
P-Man
1,246CR
ok, here's a photo of one of my L-shape pcbs:
http://www.andysarcade.net/pix/example.JPG
I have highlighted with red circles the important bits of information i'm looking for.
I dont need you to remove the pcb from the cabinet like shown in my example, or disturb anything, you should be able to get your head in there and get photos of these parts of the pcb without too much trouble.
by all means post them on this thread, thankyou!
4,047CR
I think I've got two sets up in the loft. I've got to go up there this week for you anyway once I'm back on my feet so will dig them out.
P-Man
1,246CR
Equites said:
Andy - are you only wanting Taito stuff or will daughtercards for stuff like Zenitone's IR also be of interest?
I'll take anything you have i suppose. My only photos of the invaders revenge daughtercards are from 14 years ago and are not very large, or detailed so those would be appreciated, although they will not be part of this investigation :)
thanks!
Equites
Chief Sheesher®
34 (100%)
3,299CR
thanks!
Andy - this is a pic I took of my IR daughtercard some time back, I will email you the high resolution original image and of the motherboard plus my spare Taito SI set. I will also make note of the cab serial number.
The IR Daughtercard has many unmarked ICs, but I have been able to work out that the two 40 pin ICs are a 6809E CPU and a Sound IC (forget which one). The other smaller unmarked ICs are just standard TTLs as far as I could determine. I did make notes, I will dig them out.
P-Man
1,246CR
no? no pcb photos at all?
i'm also looking for photos of the rom board (bottom pcb) in cocktail 3-layer pcb sets too..
so far i've had zero responses... there's hundreds of these things out there....
please?!
Jase
280CR
Andy, I've got the 3 layer Taito Pt II (b/w) that you've had in your hands a few months since, with the screen-flip issue (which has been cock-on ever since).
Is it worth sending you any pics of this? I'm about to pull it to fit my Braze kit, so...
P-Man
1,246CR
Purity said:
I thought you wanted a picture of the linear power supply on the Pt2 ?
There shouldn't be a linear psu in a part 2 cabinet... but i dont remember requesting that either? the threads right here :)
Purity
The Oracle
17 (100%)
2,998CR
This was on IRC. Maybe it was nothing to do with this, just to help with diagnosis?
You could just say you don't need this
Purity2013-10-23 17:56:02
P-Man
1,246CR
Ace` said:
http://www.games2replay.co.uk/siromboard.jpg
This any good to you? rom board from a black and white 3 layer board. This board has had the single rom mod started on it, if you know the original jumper settings or have a picture with the correct jumpers I'd appreciate it.
Thanks for the photo, helps fill the gaps :)
So were there no roms on the pcb when you got it? CVN00006 should be fitted with 4x 2316 mask roms, (TV01 or TV0H), TV02, TV03, TV04. But, you wont be able to find those, so you're probably wanting to fit it with 2716 eproms, so use the jumper settings shown on this pcb :
http://www.andysarcade.net/pix/CVN00010.JPG
good luck
