Taito Trimline new build - 18mm Plywood or MDF
G
Guests
Guest
At the end of the day, when you think Atari were knocking out thousands of cabs using ultra crap particle board, any type of ply is going to be a better job than that! Even Williams, using MDF for lower front kick panels on some Defenders.....bonkers when the rest of the cab was ply anyhow.
Carlito3
115CR
Customshop Designs (first place I went to) revised their quote to £200 when I told them I needed 2 side panels (they obviously didn't put two and two together (sorry!) and realise I would need two side for a cabinet).
Emailed a couple of other local companies but 18mm ply from Customshop Design is looking like the way to go.
Watch this space.
edget2000
131CR
Watch this space.
Please keep us informed of your attempts to find a decent company. After this thread you've got me thinking about getting a couple of cabinets made up where I just can't seem to find the game forsale over here. Galaga/Wide Body Nintendo, I could name a view...
cheers
Tony
Sluggy
71CR
Just a quickie... I built this using MDF so I could dowel and glue the joints..... the cad plans I done for this trimline are I beleive still stored on the cnc cutter i used so setup will be done making a cut cheaper than a new cnc setup so might be worth getting a quote from the same place I used for the 1 off build, let me know if you want to try this route
Sluggy
