[Tech] trackball challenge
LukeWells
334CR
[ukvac] [Tech] trackball challenge
Can a cheapo PC mouse be hacked so it could be used to test the inputs on trackball games? Could the outputs be tapped off before they are converted to serial?
Luke
pobtastic
477CR
Macro
2,009CR
RE: [ukvac] [Tech] trackball challenge
check out link from http://www.arcades.org.uk/PCB-Hack.htm on how to use an
amiga mouse on trackball games.
(I bumped into it recently) - don't think you would be able to use a PC
mouse in quite the same way, as it decodes the movement and transmits it as
RS232 signals instead! (Atari ST mouse should be possible too)
This document originates from within the Bounty Group of Companies.
Whilst we have taken steps to control the spread of viruses on our
systems, we cannot guarantee that this file is virus free.
This message, together with any associated files, is intended only for
the use of the individual or entity to which it is addressed and may
contain information that is confidential, subject to copyright or
constitutes a trade secret. If you are not the intended recipient of
this communication you are hereby notified that any dissemination,
copying or distribution of this message, or of any files associated
with this message, is strictly prohibited. If you have received this
message in error, please notify us at once.
Please visit us on the web - at www.bounty.com or www.diss.net
pobtastic
477CR
Macro
2,009CR
y> [tt] check out link from http://www.arcades.org.uk/PCB-Hack.htm on how to use an
[/tt]
zepromz
77CR
Re: [ukvac] [Tech] trackball challenge
>to serial?
Yes, somewhere between the opto and the output you will have a 5 volt
quadrature
signal pair from each axis (X + Y), get your scope/probe out and trace the
circuit
to the point just before it gets converted to RS232.
Easier than it looks, not that much goin on in a mouse...
Macro
2,009CR
doh! - of course, I did a trackball to PC conversion using the control board
out of a mouse, but the same info would be just as relevant for picking up
the signals directly and not removing the led's and optical receivers -
easiest place should be from directly underneath these on the board, since
the will have GND,5v and he 2 optical outputs in one location.
I was thinking that your couldn't just plug a PC mouse direct to a PCB, but
all the signals needed are in there somwhere. The bit about vane sizes may
still be relevant though, since some mice have drastically different
mark/space ratios which could make it a little unusable (I tried a Logitech
mouse first, and whilst it worked fine at low speeds, it went totally up the
creek at higher speeds!)
http://www.mameworld.net/pc2jamma/trackball.html
>quadrature signal pair from each axis (X + Y), get your scope/probe out and
trace the
>circuit to the point just before it gets converted to RS232.
