Tekken 5 Sit Down projector cab
leeram
44CR
Ay up everyone,
I have a massive sit down Tekken 5 projector screen arcade cabinet but I can't find any information about it.
Does anybody know where there's any information about this specific cabinet I can be linked to, I don't even know the proper name of it? I've searched but can't find anything.
I can only describe it as massive all in one (when it's bolted together) sit down cab with a projector tv for the screen.
I'll post some pictures a little later today.
Edit, video here :)
https://youtu.be/AuF8XNeWbBo
Cheers,
Lee
leeram2020-12-09 11:42:14
5,332CR
My projector senses are tingling
It's one of these, isn't it?
https://www.ukvac.com/forum/data/uploads/2675/Showcase.jpg
There's a guy in Oldham who had a couple in his stash (that are going on eBay).
Sadly I think, like many 'showcase' cabs, there's not much info out there.
I thoght Tekken 5 would be VGA, but is that a JAMMA multiboard in there? (so the projector does 15kHz as well?)
I take it there's 3 CRTs in there? They usually need about 10 minutes to warm up, but you'll get a lovely pictures once they do, if it does native 15kHz.
You might find it needs a remote to set the convergence if that's off.
Definitely need pics of the internals
edit: or is it a multisync DLP projector and a lot of that is irrelevant?
John Bennett2020-12-09 13:46:39
jinq-sea
237CR
Tekken 5 (system 256) will run at 15kHz interlaced, so it could be a 15kHz cab. I don't know much, if anything, about the Showcase projection cabs though.
leeram
44CR
Cheers John, I found the manual.
It's a Tekken 5 super DX.
Just going through the manual now.
I know nothing about projectors but it didn't take 10 minutes to start up. It started instantly.
The monitor doesn't work with 15kz, probably. I don;t know if my little iCade 60-in-1 pipes out CGA through the VGA adapter, if not I might have to rig the JAMMA up to the projector and it could work I guess. But I have no need to find out.
Cheers,
Lee
5,332CR
Ooh, it's probably a CRT. By 10 minutes, I mean the red, green and blue might not be converging exactly until 10 minutes - the corners particularly will be out, but once warmed-up, it might be ok (if not, it'll need adjusting digitally somehow
One brief mention of it:
51" Arcade Projector (curtpalme.com)
Would be sweet if it was multisync. Please never fit an LCD in there (or give me the CRT bits if you do
Is it a paper manual you have? (if it's not on the net, it'd be good to have it scanned).
Flinnster
The Dino King
29 (100%)
2,566CR
Ah there's no way a dedicated original Tekken5 cab would have been standard Jamma originally.
The manual might help with the wiring there, you'll see right speaker is on another connector completely (not wired to the standard jamma edge):
https://www.bandainamco-am.co.uk/files/53
This might help too:
https://www.bandainamco-am.co.uk/files/55
See if you can get connectors that would allow you to clean up the cab wiring back to standard Jamma, without actually hacking up the wiring would be my advice.
If you are only interested in emulation, then it seems that cab is pretty much set up for a VGA input from a PC or a Pi. You'd just need to cleanly wire up the existing control loom to however you want your controls to be fed into the device (via JPAC or direct) and sort out the cab's 4 pin audio connector to matching 4 pin plug connected to a 3.5mm jack for stereo sound.
(I take it if you unplug the VGA plug from the 16-in-1, you'll loose the picture completely?)
And yeah, open up that PSU, hoover out all the crud and possibly give the fan a clean down with isoprop alcohol and some wipes to get any sticky gunk off it.
Flinnster2020-12-10 11:06:45
jinq-sea
237CR
I've got the full 256 Tekken 5 kit, and it came with a JAMMA connector adapter which has the stereo connector and kick harness on it - it's possible it was JAMMA. Although, if it's a 31kHz projector, it'll possibly have been JVS.
Pictures of the inside please! :)
Smraedis
105CR
Sure remember seeing Tekken 4 and Soul Calibur 2 often in these cabs. I never liked the sticks or buttons these came with though!
