Step 3 - Fixing OR2 (Outrun 2 SP)
There are a number of things needed to be done to get OR2 working.
1. A number of graphic shaders need to be fixed to work with NVidia GPUs on Windows. These fixes have already been applied to the download of OR2 above, so you don't need to do them. If you have obtained OR2 elsewhere then it would be worth doing this fix. Download the file outurn2_nv_shaderfix_jennifer.7z from this post and extract the files into the location you have extracted OR2 to. You would need to extract into the /disk0 folder as this contains the Jennifer folder.outrun2_nv_shaderfix_Jennifer.7z 5
2. The executable file for OR2 is known as an elf file, and it's location is /disk0/Jennifer/Jennifer (no it doesn't have an .exe extension). This file is hardcoded for a resolution of something like 800x480 and has problems with shadows if run on PC. I have included 4 fix files here, which can be used to extract a new Jennifer file, which will have a different name. You need to select and use the file based on your full screen resolution. I have included fix files for 1920x1080, 2560x1440 and 2 for 4k resolution 3840x2160 resolutions. I am unsure what, if any, difference there is in these two 4k files but I have included both. You need to extract the file to the /disk0/Jennifer folder. Don't worry it will not overwrite the original Jennifer file as these all have different names for the Jennifer file. 1920x1080.rar 8 2560x1440.rar 6 3840x2160.rar 5 3840x2160 alt.rar 4
When you have extracted the new Jennifer file make a note of the name of the one you are going to use, they are called:
Jennifer_patched1080pfix
Jennifer_patched1440pfix
Jennifer_patched2160pfix
Jennifer_patched2160paltfix
https://www.desertislandfruits.com/forum/index.php?/topic/4220-outrun-2-sp-dx-lindbergh-on-pc-using-teknoparrot/Retroman8392022-04-05 00:01:47
