Tempest graphics glitch
Mark H
98CR
Hi All,
I bought a Tempest cabaret from Nad (Equities) last year which I play regularly as it's one of my favourite all time games along with Asteroids.
I played it yesterday and it then developed a graphics display fault on some of the screens in that the "blue" grid lines became corrupt and started to move around and glitch and distort. The sound worked fine though.
Is there a quick fix I could do - could one of the chips be loose on the board and if so what would you advise please? I have the original manual too.
Mark
Mark H
98CR
Hi Dan,
For clarity is this the interconnect cable the connector that plugs into the board? What are the header pins and where are they located on the PCB please ? Are they the rom chips (around 13 in a line)?
Mark
DanP
Administrator
2,232CR
Mark H said:
Hi Dan,
Mark
The interconnect cable is the cable that joins the 2 boards together (the main PCB and the smaller aux PCB). Have a look here to see the cable I mean and the two places it plugs in. The "prongs" it plugs into are the header pins. These generally need to have there solder reflowed where they join the PCB as they crack over time although I suspect as this came from Nad that this was already done.
As Nad suggests, try self test too first.
HTH
Mark H
98CR
Hi Nad/All,
I took out the PCB and checked the interconnect cable and it looked ok and I pressed it slightly to see if it was tight. I then ran the "self test" procedure (as per pages 7 & 8 of the manual) and no RAM, ROM or EAROM failrues were recorded on the test screen (as per page 8). I then switched it on and the glitch seems to have gone. I however have noticed recently that the screen display at the top and bottom of the screen is not 100% horizontal and the letters/numbers displayed towards the sides curve up at the top of the screen and curve down at the bottom of the screen (a slight warped effect) although the central game display with the blue tube wires frames is fine. When I did the self test procedure 2 (page 8) there was also no white frame which according to the manual should be visible and within 1/2 inch of monitor edge. How do I change these display settings please; is it adjusting the PCB or adjusting the back of the monitor?
Thanks again.
Mark
Mark H
98CR
Hi All - I adjusted the 6 X/Y pots but I still have this issue in that the screen display at the very top and bottom of the screen slightly curves up and down respectively so the letters/numbers are not 100% horizontal. Any further ideas please however it does not impact the game play as the central part of the screnn with the tubes is fine although I noticed some of the edge of the tube designs are slightly off the screen at each side so you can't see the edge of them.
Mark
