Tempest PCB repair?
Brabus
18CR
Is there anyone on here who works on Atari PCB repairs? Had a few issues arrise
voltages on the board were fine, fired it up for the first time last night and it worked, after the spinner went nuts for a while it settled down and i played a few games.
turned it on today and couldnt start a game as un responsive buttons.
Got into the test menu, managed to test everything once and it worked.
I guess the Pokey/s were going
It started to show a few problems (on test images)
decided to take the board out, remove pokey chips to clean etc and the prom (in the image attached) Upon putting back it got worse.
The coin door light went out and the credit mechenism stopped working. The one and two player buttons pulse 4 times at a certain rate, then change to a slightly different pulse rate after. And there can be garbage on the screen now.
I cant run the self test anymore as the buttons arent responding and putting it into test mode only shows the screen in the images.
Im guessing i need to atleast replace the 3 chips i removed as they are probably failing / failed now
But any experts in this area around?
Oh and also found two wires near the power brick that have loops, are they supposed to be secrued to the metal bar with the nuts that are there? (image) currently free floating
bogbean
37CR
Let us know how the repair goes. I have seen some posts online about bringing pokeys back to life by baking them. Probably best to try when sure the pokeys are the cause of the problem though.
Brabus
18CR
You can get modern replacements, supposed to work. Not sure baking is a long term bullet proof fix, seems a bit of an unkown. But if it works i guess better than having them broken.
PokeyONE V2 FPGA Atari Pokey Replacement​
Dave2084
456CR
I tried this with a number of broken ones I had on my bench and it did revive one for a few minutes then it died again.
I think I did 10 minutes on the air fryer on max crisp ...
Won't bother again.
Brabus
18CR
Well i managed to get the machine inside, put the board in and turn it on thismorning. The board works, managed a game but that didnt last long. Static sound started happening over the game, then the screen blacked out and the player 1 and 2 buttons started flashing.
Off and On and managed to get the attract screen to show but then it jumped to black along with a few beeps and static. Now its always black screen with flashing buttons and sometimes loud static coming on over the speakers. I think the main board is still fine though.
Oh well, back to square one.
@bogbean
Brabus
18CR
@bogbean
Someone clever told me to pull and clean the connectors then re seat etc :)
Working fine now, and so far stable.
Mc-Q
1,450CR
some people replace the cable that links the 2 boards,
i dont think thats needed unless it's been damaged by people pulling on the wires, but resoldering the pin headers is probably a good idea
Geekfix
25CR
This is always the first step with these boards, I also wire brush and check the pins are clean. Also give the whole board a physical bounce test on the bench.
