Tempest WG6100 testing
bogbean
37CR
I'm working with Lastspaceship on his Tempest cabaret and I'm looking for some advice on testing the WG6100. Here's the story so far...
Tempest working well until December but occasionally the screen would go blank for a minute and then come back on.
Spinner stopped working.
Suspected pokeys. Swapped B/C2 and C/D2 pokeys, spinner now working but fire buttons now not working so appears to confirm bad pokey now in C/D2
Took a week break whilst waiting for pokeys to turn up on ebay.
Next time Tempest powered up the monitor was blank. Put pokey replacement on hold.
Attract mode is running (see picture from scope), board outputs seem ok (scope is set to 2V/div)
Spot killer is not lit. Deflection chatter heard.
All fuses in tempest power supply and deflection board are ok, no burning smells
monitor already had LV2000 fitted, noticed the +ve voltage rail LED was flickering / dim
Voltage measurements with everything connected:
Video B+: around 77V
+28V rail: around 0V
-28V rail: -21V
Briefly turned up the screen pot on LOPT, some vectors being drawn in lower right corner of green but hard to read them, very distorted.
Ran deflection board on its own (everything else disconnected including Q102/Q103, Q605/Q606, Q705/Q706) voltages now as follows:
+28V rail at P100 pin 3: +26.6V
-28V rail at P100 pin 6: -26.3V
Performed 'diode' tests on Q102/Q103, Q605/Q606, Q705/Q706 from connectors to deflection board: all PN junctions as expected, including no shorts across collector-emitter , no case (collector) to chassis shorts
Degauss coil resistance measured = 4.2 Ohms
Yoke measured: Red/blue (Y) = 1.1 Ohms, Yea/black (X) = 0.5 Ohms
Deflection board inspected and components tested. All diodes ok. All resistors ok (except R106 in degauss circuit is open, probably my fault for running without the degauss coil).
All electrolytic caps are nichicon and look to be recently installed, no signs of bulging. No shorts.
All transistors tested in circuit. Some results around Q603/Q703 required more investigation but were very similar when compared between both amplifiers. Q703 desoldered to investigate further, all junctions good so Q603 also considered good.
Summary: Deflection board believed to be ok
Followed 'How to Bring Up a 6100 Color Vector Monitor' steps 0 to 4.
Continued with step 5, i.e.ran deflection board again, this time with Q102/Q103, Q605/Q606, Q705/Q706 and neck board plugged in (but not HV board): voltages not measured by LV2000 LEDs now steady
At this point I assumed the HV board must be at fault.
Board inspection showed no problems. All resistors and pot measured ok. All transistors measured ok. All diodes measured ok in circuit. Had to remove D902 to test it. T901 read 17 Ohms on the primary and 0 Ohms on the secondary. I think that may not be unexpected, I don't have a milliOhm meter.
555 and LOPT assumed to be ok since the video B+ was previously measured at 77V so it must be running.
I am now wondering what to do next. I only have one bench power supply so can't test the HV board on its own. I saw that being done on another post and thought it was a great option to be able to do, I will have to get another power supply.
I would like to confirm the HV board is ok by testing the deflection board, HV board, yoke and degauss together but without the neck board connected (that would be the next step). I can't see how this would damage anything but I'm seeking advice if that is a safe step to take. If that works I would test with the neck board connected.
It's a long post but I'm hoping it may one day serve as a repair log.
Mc-Q
1,450CR
does that scope have a Z input? just curious because it's handy ffor vector work and none of the modern lcd scopes have it :(
bogbean
37CR
A friend refers to this as a ham, egg and chips. Unfortunately no Z input but it still displays vectors better than on my lcd scope.
bogbean
37CR
Was still puzzled over what's up with this tempest...
R106 replaced.
Found a nice way to test part of the horizontal drive section...
Applied 9V from bench power supply (with current limit set whilst I brought it up) to cathode of ZD900 and 0V on the anode (which connects to the -25.9V rail). This powers up the 555. Saw 19kHZ square wave at 555 pin 3 (output) and followed it through Q904, Q905 and also onto Q906 base (confirming that T901 was ok, I had been wondering about the low resistance on the secondary).
Now more convinced than before that the HV section is ok so did a full power up of monitor with all connections made but with game board disconnected: saw good Video B+ and no sag on B+. Repeated test with game board connected, game came up on screen! After a brief warm up Video B+ measured at 180.8V and HV measured at 19.3kV, good enough for the girls I go out with.
Not sure what has got it working again, unless it was one of the solder joints I reflowed although I can't think how that would result in dragging the +25V down as I'd seen previously. Need to give it a bit of a run to see what happens over a few hours. Bit of a lesson learned to check the basics thoroughly before diving into board inspections etc.
So back onto the original pokey issue. Currently start / fire not responding but spinner ok: pokey C/D2 suspected. Removed it, marked it with a yellow dot, baked in the air fryer at 160ºC for 8 minutes and... all buttons now working again, but let's see how long the fix lasts!
Lastspaceship
205CR
No chips were cooked during this fix.We did have a genuine oh sh*t it worked moment on this. should name this the fix tempest with air fryer thread. Other heating methods are available..
