Test/tech kit
DanP
Administrator
2,232CR
edwoodjnr said:
I was wondering what the recommended kit for someone wanting to begin PCB diagnostic and repairs would be? PCB's such as Star Wars and Tempest.
Any suggestions beyond the basic soldering iron and multimeter? I would imagine some of the kit mentioned above would be hard to find these days, are there any modern equivalents?
To begin with for vector stuff I'd go with this order;
Digital Multi Meter
Logic Probe
Game schematics
Oscilloscope (to use as a scope and a display to save you busting a real vector monitor)
The hardest part is understanding the circuit(s) from the schematics (something I still struggle with). If you get that I think you can debug most things with those tools. Once you have the basics you can start thinking about Fluke 9010/9100 to see what the CPU sees. All depends on how deep your pockets are all this stuff is still available just not cheap.
HTH
Dan
edit for spelling
DanP2013-02-11 22:31:07
andrewsm
485CR
Not as an extensive list but enough for debug.
Iwatsu quad channel scope
HP 3488a switch contoller rigged up to switch video and power to a variety of non jamma boards.
Standard portable TV used as RGB monitor
5inch B/W monitor for composite
Logic probe
Home made Arduino IC tester and 8080 simulator.
Soldering station.
Electronics knowledge Lol
Purity
The Oracle
17 (100%)
2,999CR
Got a few bits in the locker:
2x Fluke 9010a troubleshooters with 68000, z80, 6809, 1802, 8080, 8086, 8088, and 6502 pods
Hameg HM203-6 20mhz scope
Philips PM3055 50mhz scope
Siglent SDS1102CNL 100mhz digial scope
HP Agilent 1650B logic analyzer
LWLA1034 logic analyser
HP5006a Signature Analyzer
Dataman 40 Pro
BK Precision 864
Micromater LV48
Data I/O 29a with unipak (unipka 2b soon)
ABI Chipmaster
ABI Boardmaster
AR81 with z80 and 6502 pods
Metcal SP200 soldering station
Hakko 808 desoldering gun
426DLX Fume Extractor
HP10529A Logic Comparator with HP logic probe/pulser
Gauck Comparator
Tenma Logic Probe/Pulser
Stag SE15 Eraser
UV141 Eraser
Atlas DCA55 Component Tester
EDS-88A CapAnalyserII
MESR-100 ESR Meter
FG601 Function Generator
Paul Swan Arduino Tester
Other things like a Soldaputt, AMP 40KV HV probe, Caltek CM1200 Multimeter
Homemade Supergun setup
.....think that's about it
Purity2019-06-14 10:57:37
Flinnster
The Dino King
29 (100%)
2,566CR
Just a load of blu-tack and a hammer. Job's a goodun
Mike Mnemonic
9CR
The main tools I use are ..
1. Brain
2. Internet
3. Weller de-soldering station
4. Weller hot air reflow station
5. Metcal soldering iron
6. Fluke multimeter
7. HP 100Mhz digital scope (I would recommend analogue!)
8. Bausch and Lomb microscope
9. Custom test jig (PC + 3 * parallel port + support s/w in Turbo Pascal!)
10. Atari CAT BOX
11. Custom design CAT BOX II (still in development)
12. Saelae Logic 16 logic analyser
13. HP10529A Logic Comparator
14. HP5004 Signature analyser
15. HP545A Logic probe + current tracer
Most useful tools for debug are brain, internet and scope.
Regards
Mike
69er
1,852CR
i just referred back here and love that above "Brain".....thats clearly the best and such it follows some simple everyday things too....... ..
it surprises me how many of the above seem to struggle without most basic things and yet invest heavily in test equipment
from a very early time back around 1980 i have always had a hand held make up mirror like the wife would carry in her handbag . so ..........
MIRROR ....... invaluable when needing to set height, or vertical hold etc from the rear and you cant reach from seeing screen just hold the mirror in one hand and adjust with the other
things like telecopic dental mirror for the power supply fixing screws down in the dark of a cabinet bottom
telescopic magnet for those dropped screws ............. and a small bright torch for both those applications
a torch these days is usually on your iphone NOT MINE my mobile is dated ITS ONLY A V3 but i dont risk smashing my screen ........ BUT .. a phone to take a picture before you dismantle wiring TAKE A PICTURE for reference when reassembling
69er2021-02-02 11:29:22
Velyks
100CR
Ohh I was just thinking about making a "Whats in your toolbag?" post.
I'm generally repairing things out on the floor and I don't have a car so I've picked all my bits on being portable. I'm just going to list the stand out tools that I consider more than helpful or better than average, of course my toolkit is stuffed with various small bits I've picked up here and there.
Head Torch - It took me way too long to actually get one of these. Focus and flood LEDs, mandatory round the back of cramped machines.
Wera Kompakt Screwdriver - Contains all the bits I need and has an extendy bit holder. Good quality PH2 and PZ2 bits make all the difference.
Hex/Torx Security Bits - Two sets, come in one little yellow rubberyplastic holder and are heaps better than the big security bit sets because the security holes are actually well centered.
Wera Zyklop Slim 1/4" - A great little ratchet, surprisingly strong.
Wera Deep Sockets 1/4" - Nothing is more annoying than bottoming out a socket. The holder these come on is a great idea too.
Pinecil Soldering Iron - Amazing soldering iron! Cheap, takes TS100 tips, can be powered by USB-C (PD) or a barrel jack. I run it off a 65w USB-C charger.
Engineer SS-02 Solder Pump - The only pump I've used that actually sodding works.
Engineer PA-01 Crimp Tool - Works for American and Japanese button crimps, AMPUP connectors, the lot. Good wire strippers on it too.
Engineer SS-05 Soldering Stand - Separates into a sponge tray and a stand. The seal is pretty good so you can wet the sponge and it'll stay wet.
Engineer DA-01 Pot Twiddler - Bit of a luxury but when you've got your arm stuffed behind a CRT it's nice to know the thing you're prodding it with isn't conductive.
Engineer NSX-04 Side Cutters - Proper meaty side cutters, have lasted me years longer than the generic brand ones and are still sharp.
Metrica Vernier Calipers - It's a lot easier to find the right spare part when you know the exact size of it.
MINIX 66W USB Charger - Powers my soldering iron, charges my head torch, phone, and laptop. Bulletproof.
Other generic tools:
- Adjustable nutf**ker
- Torx L-keys in 20, 27, and 30 (Sega cabinet sizes)
- Cheapo multimeter
- Various consumables, leaded solder, electrical tape, heat shrink, solder wick.
- Big and small pliars
- Couple lighters
- Tiny slotted jewelers screwdriver for popping out AMP UP pins
- Some big paper clips for the same purpose when I lose the jewelers screwdriver
At home it's all this plus a Rigol 1054z.
Edit: Oops, didn't realise this was from 11 years ago, sorry for the thread necromancy.
Velyks2021-08-11 12:37:26
  • Like
Reactions: lix
Phils Arcade
1,529CR
See a lot of folks using Fluke Multimeters. I've a really old 40 year old cheapo one but is starting to show it age.
Been looking at the Fluke 17B+ Digital Multimeter. Seems to get a lot of good reviews for what it is and wondered if anyone here has had experience with it? See it also has calibration pots if you have a good source so it can be fine tuned.
robotech
823CR
There's a small cheap fluke meter fluke 101 made for the Chinese domestic market but you can get it over here
There's a shootout video on you tube where a guy puts all the cheap multimeters through there paces and this wins it
I've had one for a few years now and it does everything I've needed I think there only about £40 too
I also have an old school fluke bench multimeter but I don't use that as much as the 101 robotech2021-09-10 11:33:50
5,332CR
Trusty digital scope with logic analyser
and whatever soldering equipment I've borrowed/nicked (presently got dad's Hakko desolder tool which is fantastic).
Plus homemade 'supergun'
