Isn't WD40 highly flammable?Use oil to cool your bits. I always have a little pot of wd40 when I’m drilling through tough metal that I either dip the bit in or spray on it. 15 second bursts
…and that Fella is why you fooked them up!i was going hell for leather with the drill on full blast
If you use it constantly the bit doesn’t get hot. That’s the point.Isn't WD40 highly flammable?
If you can get at the lock even a little, it’s worth spraying some WD-40 in there and then gently trying the key again. Sometimes you just need to give it a few minutes so the lubricant can work its way in and free things up. Just don’t force it too much, or you might end up snapping the key or damaging the lock.I DONT KNOW WHY HE HASNT ASKED ME FOR ORIGINAL WINFALL KEYS ? .. .. I have loads as one pair come with each lock and both locks on front same key - the whole 700 or more cabs all had suited exclusive locks and keeping a pair back from each machine I have hundreds of 284013 worth a try in my opinion?
Once the lock gets half drilled too late to try correct key so will need to continue snapping drill bits or just pop the door open with a decent big screwdriver then straighten the door edge with pliers and fit a new lock!
I posted a picture of them back up this thread
Unless someone else has swapped them but machines are little used why would they swap unless they lost keys?
I'd also be interested to hear what you think of this site - it has a lot of cool games with simple controls. I tried a few of them and really liked them. I'd appreciate your feedback.
He doesn't have keys mate hence the drillingIf you can get at the lock even a little, it’s worth spraying some WD-40 in there and then gently trying the key again. Sometimes you just need to give it a few minutes so the lubricant can work its way in and free things up. Just don’t force it too much, or you might end up snapping the key or damaging the lock.
I have been drilling quite a bit of mild steel of late ..I've found UK locks quite easy to drill through only blunting cheap drill bits I got free with a Staples order over a decade ago lol!
It's Japanese security locks I've struggled to get through even with high quality drill bits. Titanium bits are expensive but worth every penny in terms of time and effort. If buying from Amazon read the reviews as some are crap.
If Norm has the keys your laughing !!!
For the record the drill bits my dad has are Dormer Drill bits. Expensive but the best apparently.
Dave,
Sadly OH NO YOU CANNOT !
You can reach in and unclip the game board drawer and button panel pulls out front of cab…. Unplug any game edge first
The buttons and sticks plug off the loom also slide it fully out of the cab.
But you only reveal a 4” gap right at front above mech … if you can get down there from the rear to undo a lock tongue WOW!
The gap is so you can reach in from the credit door to unclip the CP save pulling machine away from wall in pub or arcade to swap boards…. Mark spent months designing the pedastal cab to try make it best all round … the reason the coin tower is pedastal is so a foot throttle can be fitted on base for final lap3 and other games using a swappable steering CP like also pictured below
Then you can’t get to the coin box lock via a small hole below the mech exit and the coin box is almost full height of that compartment blinding any chance of lock access
This box of keys all identical spare from locks on Winfall cabs at time of sale new
284013 tho no guarantee Smith didn’t swap them for unique odd locks?
If so it’s pop it open with a big screwdriver careful not to bend door rim too much , pliers will restore shape? Or buy one of these lock bump picks 7.5mm size as they come in various sizes for seven pin round lock . Can’t just find my 7.5mm one !
the guy I passed mine on too said he had the steering wheel
