Thompson d9200 help
8,288CR
So I have just realised I have a d9200 wells chassi
Nos
And a Thomposn tube ..
I know d9200 was paird with thompson A68.
A68aga20x 101 Will this be ok to pair up ?
I have measured the yoke
Will update yoke speck here
SegaSaturn94
6CR
The tube could work, but you would have to measure the impedance of the yoke to make sure. If its within a certain range, it might be okay to pair up...
However, that's not the only thing that must be checked: if the tube does not physically fit in the cabinet or the mounts are too far back, then you could also have problems.
But even if the tube doesn't work don't toss it away! According to the following thread, that exact tube model is compatible with a Nanao MS9 chassis! (Go to the bottom of page 1, and then to page 3 to see the results.)
https://www.arcade-projects.com/threads/alright-school-me-please-nanao-ms2930-31-33-tube-swap.10688/
So even if the tube is not useful to you, list it on here so someone with a Blast City can use it!
SegaSaturn942022-07-08 21:44:17
8,288CR
Nice !
Thanks for that
But would be nice if it fits windy 2,
I just need to get to it..
To read it hopefully tomo
I don’t have it in a frame …
I need to get a frame .. for itRetroman8392022-07-08 21:49:31
SegaSaturn94
6CR
You're welcome!
If you need a replacement tube for your arcade machine, go on Facebook Marketplace to find 29" CRT TVs. Sometimes by getting the model number for a set, you can find the service manual that specifies the tube model that went inside that TV model/chassis. If the tube isn't reportedly compatible based on forum posts, then look for another.
To find out the specs for picture tubes, consult this site: Tubular.atomized.org
