Time Crisis 2 gun initializing issue
Itsmecurrie
99CR
Yet another gun issue for me to diagnose 💀
Time Crisis 2 twin cab. Working grand last month, took it out and hooked up the pedestal as usual (same pattern each month for our events)
But this time the play 2 gun just would not initialize with accuracy.
Gun fires, recoil etc, and the hits register on screen sporadically, but they are landing (sometimes ) and registering in various points on the screen. The accuracy bounces all over the screen.
I've tried:
- Taking the gun apart, reseated connections
- Cleaned the lens
- Swapped guns (still same results)
- IO PCB test came back with no issues
- No ram issues on start up
- continuity check on gun molex to io PCB
- continuity from io PCB to molex leading into main cab
Nothing discovered.
I'll next start testing the continuity on the inners within the cab.
But just if anyone else had experienced this and knew of a fix I'm overlooking that's be great.
Stephen
Itsmecurrie
99CR
Yeah guns are totally grand after all the tests
I'll swap the IO PCBs next (strange as it wasn't failing any io PCB tests)
I've a feeling something in the main molex that connects the pedestal to the unit is at fault as that's really the only area that we touch in setting it up. Pulling the connections apart and resting each event.
But I'd have thought I'd get the usual sub CPU issue when there's a connection problem
tb2000
3,575CR
That's good. I've seen problems occuring such as this in Namco cabs (probably in others as well) in other parts of the loom no doubt because the molex plugs are 25 years old or so! Easiest solution to get round it i've seen is just to cut out the molex plugs and solder the wires together directly. Makes swpping out parts harder but does eliminate bad connections (usually!)
