Time Crisis C404 error
UK_Gamer
44CR
Hi guys,
A friend of mine has asked me if I could be of any help as he know's I have a few machines.
He's having an issue with player 1 on Time Crisis 2, player 2 works absolutely fine.
Has anyone had this C404 error before and know how to resolve it? The test runs for about 20 minutes and then loops and does it again.
tb2000
3,584CR
If the self test is to be taken at its word, it looks very much like a colour ram error. Look for 14F on the pcb, it'll be some sort of surface mount RAM chip. Replacing that is the best place to start.
Edit: To be honest, if that one's gone then the other two probably aren't far behind, so best to obtain more than one ram chip.
tb20002019-01-21 22:36:52
tb2000
3,584CR
Thing is with these is that you need someone who's got either an orignal cab or a test rig wired up to be able to test it on. I have got the parts/pcbs to make a namco system 23 test rig but not the loom parts required as of yet.
IanH
277CR
I tried everywhere to try an find somebody to fix one from work with the same fault, but couldn't. But eventually got one part exchange from sonica services, I think that's what they were called. I have there phone number I think if it would be any use?
tb2000
3,584CR
It should be a fairly easy repair with the right tools (you could even do it with some Quikchip to save getting involved with surface mount removal gear), just testing isn't possible without the right kit as I say above.tb20002019-02-05 10:26:16
