Time Crisis II- PSU problem
gunblade
9,148CR
just use a 16a one you fiond on ebay, try to use a reasonable quality one, buy some ring terminals as well so you can get a pro connection onto the supply
Smraedis
105CR
Glad to hear it's all better now! I use a basic arcade PSU for my TC1 setup.
bobbydilley said:
The IO board (Sub CPU) is checked once at boot up and then no error checking is done on the JVS communication that is passed through. You're IO board can die during game play and it won't care. You can unplug the IO board whilst the game is running and it won't care - plug it back in and after about 20 seconds it starts reading from the IO board again!
Regarding this, I disconnected my IO board and the game locked up and wouldn't come back on until I plugged it back in. I've not really touched it since that happened, sometimes that board isn't working for me.
I'll play around with it again soon.
BulkSlash
81CR
Right, I’ve ordered a 16A JAMMA PSU, hopefully this will do the trick and get it running solidly. I’ve still got loads of ring terminals from when I replaced my TC1 PSU so I’ll get to feed my crimping addiction with this again!
BulkSlash
81CR
I’ve finished the wiring for the new PSU, I tested it with a 16A JAMMA PSU I had lying around and even with the knob fully cranked it couldn’t hit 5v, so I hope the one coming has more oomph. I’m thinking I might have to try and wire two PSUs in there, although I’m not sure how I’d ensure I wasn’t crossing the 5v lines and grounds between PSUs.
In better news, the pedals are repainted. I decided to add a bit of a personal touch and make the P2 pedal match the blue colour scheme.
BulkSlash
81CR
Do you mean adding additional wires on the 5v and ground terminals but routing them into the same pin on the loom plug? I might struggle with that as already there are five wires on the 5v terminal, it’s really crowded on there.
It could be a bad connection somewhere in the wiring, I’ve been thinking I could get some replacement pins for the loom plug so I can replace the wires going into it.
bones
1,628CR
I had issues with a similar PSU. Pretty much done what gunblade suggested. I chopped all the 5v and 0v wires coming out of the PSU and put them a 6 way terminal block eg 2 reds in each terminal with a link going 1 to 2, 2 to 3 etc and the same with the black wires and it sorted the problem.
BulkSlash
81CR
Oh, I think I’m starting to get it. I’ve scribbled on the first terminal block image I found on Amazon. Is this what you guys mean?
BulkSlash
81CR
Right, the terminal blocks and PSU have arrived, hopefully I’ll get to it this weekend. I had a couple of weeks off at the end of last month so I was able to make good progress but things will probably go even slower now!
