This is the repair of the second Time Pilot PCB.
The board was working but had no sound. Testing the board with two soundboard sets still generated no sound so I had to believe it wasn't a soundboard error. After fixing the first PCB that was confirmed but I still was working on the premise that the fault was in the main board, which it eventually was.
My only error in this was first looking at the buffer at B2 (ls244). It is right before the connection to the ribbon cable but has a load of logic preceding it. I had changed the ls138 at A3 and everything going into B2 seemed ok but nothing was coming. I resisted the temptation to pull it and decided to work my way backwards. After going round and round and round the circuit I started feeling very lost in it.
Today was a fresh start so just ignored that part and after checking a few chips stumbled across the buffer at C2 (ls245). All inputs good all outputs stuck high (really easy to diagnose once found).
Replaced the buffer and the sound is restored - PCB repair can be a nightmare because I could have saved hours if I had spotted that first.
jonhughes2020-10-05 12:04:22
