track n field/hyper olympics pcb help
FinalFight
72 (97%)
702CR
Hi guys i have a little dedicated cab this pcbs from and its been faulty since I got it
my dad removed the battery as it was dead
it displays like the pic .. the characters seem to work and the sounds are there
is there anything I can check or anyone good with these boards?
would love to get the cab working again
sorry the pics not the best but its basically green the background but the characters are there and it seems to play
I took a pic of pcb someone might know what version it is
(pcbs ontop of a box not just lying on the carpet)
stegrey2019-08-10 16:25:41
TheDaddy
14 (93%)
6,732CR
Few simple things to check :-
Make sure +5v is ok
Remove / clean and refit all socketed chips.
Is there any background at all ?? Cant see picture great.
Dave.TheDaddy2019-11-07 22:40:49
Monstermug
1,796CR
Probably the background graphics ROM/Rams are bad. If it's got loads of fujitsu chips on them they could be bad too. If you don't know anything about fixing pcbs, the best you can try do is what Dave has suggested. If you don't mind the wait I can take a look at it for you. I've still got a stack of pcbs that needs fixing atm and don't really want to add more to the pile as it won't be fair although this looks like it might be an easy fix.
Purity
The Oracle
17 (100%)
2,998CR
The sockets are notoriuosly bad on these boards.
I would check sockets, and roms, but also use the test rom to confirm if the rams are ok. I guess that could also check the roms are ok
Shinydaz is good with these boards but not sure if he looks at them for others. I could maybe take a look at this for you if you are stuck, and in no hurry
Ben
Shinydaz
796CR
Yes as previously stated, it will probably be either be a fajitsu ic and/or socket. Give the legs a clean on the socketed chips and when it's running, press down hard on them and it might give you a clue on where your problem is. Shoestrings test rom is definitely worth burning.
