Tron sprites corruption advice
Judder
1,009CR
Had to swap in my second Tron board set as the first one was giving a ROM/RAM error (to be investigated) and I'm getting some sprite corruption as per the screen shots below
Before I go diagnosing has anyone got any thoughts as to whether it might be ROM related (replace the graphic ROMs as they are the source of the sprites raw data) or something on the Video Board that might be adding to the corruption?
Text characters weirdly look 'correct' so was thinking it might not be a video board problem, but then they are always 'blue' so it could be something with the colour combination circuit
Just to start off hopefully in the investigative 'right' direction
Thanks guys!
RGP
Meeter & Greeter
2,039CR
All the sprite stuff is handled on the last board, the middle board is the CPU and text board and muxes everything from the sound and sprite board together into output.
You've likely got a bad LS157 or LS153 in the ROM to RAM chain to get that kind of effect.
Or one of the counters which works out position on ROM vs screen line vs sprite Y position.
Its not an easy board to debug and fix and my least favourite out of the three to work on.
Judder
1,009CR
Thanks James - good tips there and much appreciated :)
So there's 18 x 74LS157 on the Video Generator P.C. ........
Therefore I think the best strategy is to test the chips in circuit using my TL86A Eprom burner which can test TTL chips too, and gives me a good excuse to use my chip test clip thing which I bought but haven't used yet
Will try swapping out my primary board set Video Generator P.C. too and see if I can get a better result with that in the short term as I wait for a very rainy day!
Will report back!
