Tron - Testing the Audio Amplifier
Judder
1,009CR
I've been struggling with the sound in our Tron for a few weeks now, so decided to isolate the external sound amplifier and test it, to prove whether it was working or not.
Thought that it would be helpful for all the other Tron owners to document how to do this - and a handy video at the end showing 'new' Tron meet 'old' Tron
1. Schematics
So the sound amp takes stereo input from the Super Sound I/O board, and 12V power, and then outputs to a pair of speakers to give the 'stereo' output that the game uses.
We need to rig up:
J3 (Input)
pin 2- audio left
pin 6 - audio right
pin 3 - ground
To do this I used a headphone jack that was rescued one morning on the way to work and simple soldered 3 wires to the pins on the headphone jack connector
pin 5 - Ground (Audio Return)
pin 8- +12V DC (Audio)
I'm using a simple switching power supply, but any +12V would do
J2 (Output)
pin 1 - audio left +ve
pin 2 - audio left -ve
pin 4 - audio right +ve
pin 6 - audio right -ve
Here's the relevant part of the schematics for reference.
Setup:
Here's a picture of how I set things up
Audio from iPhone into stereo back into pins 2, 3 and 6
Speaker (just testing one channel at the moment)
Power (note the milk bottle top - it makes a handy 'safety' for the 240V coming in the front if you cut a couple of channels in it for the wires with a Stanley knife
You can also test the audio output with an Oscilloscope
Here's it running with the nifty and very reasonably priced DSO201 Android based scope with settings 0.5V (Y-Axis) and .5ms (X-Axis)
and here it is all running together with some suitable test music
Vimeo Link
Judder2014-08-12 13:50:57
Judder
1,009CR
Important update on the above - in the write up I had the +12V and the Ground switched around
Just proved that by testing a board in the cabinet, wired it the wrong way round = smoke and smell of burning electronics
Luckily second replacement amp works fine, and I now need to go and fix the first one that _was_ working fine.
My guess is that it blew the two MB3730 audio power amplifiers - anyone done this before???
4,058CR
Yeah, I may have done that to my spare Tron PCB on Sunday
Where did your magic smoke come from? Mine was one of the chokes on the SSIO PCB but now I have a short on the PCB I need to resolve and at the moment I can't find my Tron manual (and can't read the PDF schematics too well).
Judder
1,009CR
Ha - glad I'm not alone in this
I was just testing the MCR / 2 Dual Power Amp connected to the cabinet speakers, but running off of a separate linear power supply and using my iPhone for audio input - the cabinet sounds pretty good actually with some good music going through it!
Magic smoke (and melting plastic smell) on the board seems to be around the audio amp chips, but there's no obvious blow resistors or capacitors - I plan to test them all tonight when I'm back home and see if any are now open circuit or similar.
Which bit of the schematics do you need?
I've got two pretty good scans, and the actual manual so if you need a hand tracing any of it - just let me know!
4,058CR
Ah, don't worry, I've got at least one, I think two original manuals here and I was using one not very long ago, I just can't remember where I put it down when I was tidying up. I blame my age
