We have a Gauntlet in the shop and I need to fix the board.
Interesting
logic board, I can't find any theory on it after numerous searches -
probably using wrong search terms, but one would think that "Gauntlet
Atari Service" or "gauntlet Atari troubleshooting" would get something
more useful that PDFs of the rather useless operators manual or Ed Loggs
PowerPoint. System 1 does not have a lot of info out there that I have
so far found.
Boot sequence info would be handy.
Obviously
we start with the 68010, but is the 6502 critical to the board booting
far enough to display the self tests? Not having a working System 1
board lying around to test that hypothesis I have to hope that someone
here has done such a test (pull the 6502 and see if the game will still
boot.
Of course the problem I am having is the 68010 is not
accessing the Slapstick or enabling the 6502 CPU, so it must be pretty
early in the boot (Watchdog clear isn't triggered at all either). The
Slapstick and Audio Reset (held Low currently) are not triggered at all
when I am monitoring with my logic probe.
My Fluke 9010 can do
some of the 68010 tests using my 68000 pod, so I am pretty sure the RAM
and is OK. The ROM verifies against my archive files when pulled
Also
address lines A23 and A21 are floating or near ground, and this is true
for two different 68010s. I also did a diode check of the address lines
and no obvious pulls low either by resistors or diodes are present.
Halt, etc contorl lines appear to be set correctly.
I do have
good clock signals as far as I can tell, the monitor does lock
indicating that vertical and horizontal frequencies are on target.
I
may have to break out the Fluke 9100 to be able to access the full
range of tests the 68000 pod can perform. Oh well, I needed an excuse to
fire that sucker up and learn the arcane programming language used.
On
the other hand I may as well find the original program ROMs for the
board (I have the later version code) and try them before getting too
wrapped up in test equipment. If I could get the 68000 pod to generate 8
bit signatures then I could verify the ROM access is all good, I am
taking this on faith at the moment.
Interesting
so far found.
Obviously
boot.
Also
I do have
I
On
