So in theory in my mind I thought this would work (*and make testing one of my Tron boards much easier), but it doesn't seem to in practice
The theory is I have a TTL tester (little thing from eBay via Hong Kong) which can correctly identify TTL chips which I have rigged up to a 16 pin test clip, and can quite happily test and identify TTL chips out of circuit just fine
When trying to do the same in circuit, the TTL tester just flashes Err (error) and can't seem to test any of the chips
I'm guessing this is because other connections to the chip mean that the resulting output states versus input tests that the TTL tester does aren't strong enough / clean enough / affected by other chips connected / a-n-other reason but really not quite sure why?
I did wonder if running the board with +5 and GND would remove that stress from the little AAA powered 1.5V ramped up TTL tester would help but thought the knowledgable bods on here might have alternative or better thoughts?
Regards
Judder
Here's a picture too
Regards
Judder
