Check em outBasically what I want is to use dimms for cf on a few machines
I collected the dimms
I collected the cfs from here
But not had chance to see what versions they are on
As ace says
If you got 3.03 firmware you can
Or needs tsop chip removing flashing
And then re fit.
If you got 3.03 firmware already
On a normal dimm not sure if CF
Adaptor will allow the 4.1 update to be flashed or not ?
Ok Chris, I’ll book you in for next time your round.Pretty sure you can update the versions on 2.xx if they work with NetBoot, its the earlier versions where there is no netboot support that you cant upgrade via Netboot, not sure if you have to go to version 3.x first and then onto 4.1 then 4.2 if you need none SEGA CF reader use.
I did read something about certain games having the firmware update on them or came with an update disk that worked with the earlier versions to upgrade to a netbootable versions of the firmware via GD-ROM.
You can update a non-NET dimm if you also have access to a NETdimm by swapping the top board over as long as its a bootable version of the firmware already on the Dimm.
H.E.L.p.Ok Chris, I’ll book you in for next time your round.
Sound like you know what your doing…. 🤣
