US Import
obcd
3,830CR
Also watch out for TL backlights. The ballasts for the US are made for 60HZ. In europe, we have a 50HZ voltage grid. Due to that, the ballasts heat more, and the TL tube lifetime is much shorter. It also can be pain to find the proper starter. (US sometimes uses a screw fitting for those) Further, you might see that the lamp is just a couple of inches longer than an equivalent european lamp.
And, US uses 120V. In europe we have 240V
A stepdown is a solution. Changing the power supply settings and transformer connections internally is another, more difficult approach.
edwoodjnr
246CR
It depends if the cab supports dual voltage such as Atari cabs.
I had one of mine running off an Airlink stepdown and just changed the voltage selector plug (thanks Nad) and put a UK plug on it. The only other change was to change the lighting ballast to run at 50hz to prevent it overheating.
