Hi All
So the dreaded 246's....
I have a vampire night standard CRT model cab that is playing up. Sometimes it freezes on boot. Other times it will load but then within half hour to an hour or so the screen will show almost like its lost sync and then go blank or freeze. I have done all the usual things including putting a NOS DVD drive in it and running it from a Naomi PSU as well as Suzo Happ. I have also tried upping the 5v a bit as I know these boards are power hungry.
What I have now done is bought the 246 back to the workbench to see if i can get it run stable on the bench. I am using the 246 > JAMMA adapter below:
It will successfully boot soul calibur 2, so I know the board and drive etc is working correctly, however when I insert the Vampire Night disc + security dongle, the screen freezes on the 'Connecting JVS Monitor' splash screen every time.
Does Vampire Night look for a specific IO and therefor not boot because this JAMMA adapter is not gun compatible? Could the IO also be at fault in the cab itself? I am running out of ideas, so any advice given will be appreciated! The 246 I am currently using is below, though I am having same issues with others.
Cheers.
Cheers.
