Video Huster Bootleg
Nico24
2CR
Don't worry about the ROM 8 and ROM 1 being switched, that was just something I was trying with the EPROM.
The only things I know are not kosha is that the ROM8 I'm using a 2732 not a 2716 and I haven't replace the colour PROM from the Video Hustler, so the colours should be a bit funky.
favouredson
Super Star
1,260CR
Your CPU board is not the same as mine. Yours has ICs 9-13 and 107-109 populated whereas mine has nothing in those positions other than the wire links at IC9.
This could be a large part of your problem.
You also have your ROMs either wrongly labelled or in the wrong sockets.
ROMs 1, 2 & 3 are the sound ROMs and should be on the sound board.
ROMs 4 & 5 should be switched. ROM 4 should be IC101 & ROM5 should be IC102.
ROMs 6, 7 & 8 are the CPU ROMs and should be on the CPU board as IC6, IC7 & IC8 respectively.
Nico24
2CR
Garry - thanks for looking. The labels are not right on the ROMs, I'm using the same ROMs as the Video Hustler board which were 1,2,3 for the CPU, then 4,5 for gfx and 6 & 7 for sound. The roms are in the correct order - I have 8 and 1 swapped to try out a new ROM brand with flashes faster. In any case I've tried every combination of ROM orders!
Interesting that your board is different. I can't see from the schematic that those ICs are doing anything.
Oh well - maybe this board would take a fair bit more to mod, than thought. I've noted a bunch of ICs that wire differently on Video Hustler than Frogger...
aussiekanga
69CR
I spent a hour or so this morning going over my Falcon frogger and doc all the wire mods ect
I did this type of conversion 15 plus years ago and its all coming back to me now
Send me a PM and ill forward you infomation
If anyone else needs it let me know
aussiekanga
69CR
I have reuploaded the info as doc was missing a mod
After removing the CPU mods i got the exact same screen as whar your seeing. Just for fun going to program a set of Video Hustler roms and i bet it boots fine.
https://easyupload.io/f8fvo0
Let me know if it works
aussiekanga2021-05-25 06:29:17
aussiekanga
69CR
Can happy report after programming a set of boot roms, removing cpu mod and connecting up cut track going to 74LS74 game boots fine expect for incorrect gfx ect due to not removing other mods and changing gfx roms
aussiekanga2021-05-25 10:39:04
favouredson
Super Star
1,260CR
After looking at aussiekanga's mods it seems that this was indeed part of the problem. My PCB does not have a few of those mods.
It is possible that this PCB was used for something other than Video Hustler and Frogger as my PCB shows no evidence of the missing ICs having been removed and IC93 looks to be original.
Very odd.
aussiekanga
69CR
There are 2 types of this bootleg PCB
The one i doc is the falcon frogs/hustler pcb that only runs the falcon software
The other one with the missing parts and extra space for eprom sockets is a direct copy cpu wise to original frogger which can run konami or sega software
The only difference between these 2 are the top sound pcb as trying fo run a husler sound board on a frogger cpu wont work due to wire mods
Post a photo of your pcb setaussiekanga2021-05-27 00:40:40
favouredson
Super Star
1,260CR
My board has the missing parts but no extra available EPROM space and it will not run Sega ROMs.
See next post...
aussiekanga
69CR
Interesting, You might have a original Frogs Falcon where the ones with the extra ics fitted are video hustler pcbs. There isnt any other game that i know of that runs on this hardware
Thats correct these pcbs wont run the original rom sets. and falcon roms frogs or hustler wont run in original pcb sets
Ill post a pic over weekend of the one i am talking about that has spots for more roms ect
