Virtua cop3
IanH
277CR
Hi everybody,
I've saved a virtua cop3 from the skip at work and trying to get it to run, its been sat for nearly two years forgotten in a lockup!
The big projection screen works fine, and is showing no signal. Ive checked the psu and is 3.36v, 5.08v and 11.9v on the loom and the 3 voltage lights are on the game board.
Theres no sound or anything so I don't think its booting but everything seems to be lit up, Ive never see one a these before so wondered if there was a test mode I could put it in some how, Ive tried the test buttons and still nothing.
Thanks for your time
Ian
Luka
50CR
Nice save, it maybe worth opening up the game board which is basically a modded Xbox. Check to see if the super cap hasn't leaked and eaten through the traces nearby. If it looks healthy I would recommend getting that replaced asap to prevent any further damage. Also whereabouts are you based?
obcd
3,830CR
How do the 2 led's behave that are in the middle of the filter board? There is a red and green one.
The other 3 on the side simply give an indication that some voltage is present on the 3 voltage rails.
If you open the unit and check it, make sure all fans are working properly. Specially the gpu fan likes to stop working causing the gpu to overheat. It's the most common cause of dead of chihiro's.
No sound and no video is typical what you get when the main board isn't booting anymore.
IanH
277CR
Thanks for the replies, the red an green light, the green one stays on and the red led light for a second once then went out but hasn't come back on since.
I'm in n.e.lincs
Thanks again.
Ian.
IanH2019-03-24 00:44:14
obcd
3,830CR
Remove the upper case with the dimm board and check if the case fan and gpu fan are rotating when you power the system.
If the gpu fan is dead, you can have a look at the pcb under it.
When it's brownish decolored, it likely failed due to overheating. Sometimes it can be fixed by reflowing it, but it's also possible the gpu chip itself is toast. If that's the case, you will either need a new mobo or you will need to replace the gpu.
I am currently working on a solution to use ram upgraded xbox mobo's as chihiro mobo's, but I am not fully there yet.
The video passes trough the base board (upper board in lower case) If that's defective, you won't get any video either. I could test if it produces a boot sound in such occasion.
To make things more complicated, the initial startup is loaded from a flash chip on the upper dimm board. If that's not working, you won't get any video either.
So, it's a bitch to troubleshoot, unless you have a working unit to figure out which of the boards is defective.
I recently had a bad AVIP cable (the cable between the 2 boards in the bottom box) and that also caused a no video issue....
IanH
277CR
Thanks again for the reply, yeah that souns like a very complicated system, I do like a challenge tho, and I know it was running fine the last time I powered it up, but the screen wasn't that reliable (too cold and damp for it) so it did used much.
Your xbox conversion sounds really interesting.
Ian
obcd
3,830CR
Without working unit, you could perhaps do some diagnoses with an xbox modchip and xbox scart cable. An ordinary xbox bios on a modchip should show you the green flubber animation during boot as that's embedded in the bios. An xbox scart cable should produce some video, even when the base board isn't working. If I unplug my base board gamepad connectors, I get no video from the chihiro vga connector. Using my scart cable, I can see it outputs video and shows an error 2 message.
I could not succesfull connect both a modchip and the dimm board together on the LPC bus. It's likely because modchips generate their own lframe signal, as it's missing on 1.3+ mobo revisions.
IanH
277CR
Hi, I've got the gameboard out today, its battery is totally flat and wont charge, would this stop it booting?
An I maybe completely daft but how do you get it apart? I cant get the little black plug thing on the top of it out, I've tried pressing the tiny button in but it wont budge!
Ian
prof5
50CR
not sure about the little black you are talking about, there are 4 long screw that go through the top cover, and about 10 or 11 screws around the joint between the upper and lower case.
the Chihiro in my outrun 2 would not boot when the cr2032 battery on the upper board in the bottom case was totally flat
2,272CR
Do you mean the little PIC chip?
That doesn't need to come out. That's just a security chip needed to load the game.
IanH
277CR
Yeah that it, so you don't need to take that out to undo the top?
I haven't got it to bits yet, but the battery I mean is a big 7.4v li battery.
I'll do some more investigating tomorrow hopefully.
Ian
obcd
3,830CR
The battery doesn't stop it from booting. You can simply disconnect it. It keeps the dimm sdram modules powered for a couple of days when the system isn't powered. The dimm is basically a solid state disk using sd ram as storage memory. The memory needs power or it looses it's data. In such case, the game needs to be reloaded.
IanH
277CR
I got the security key out, it took a lot more pulling than I thought it would!
Anyway its in bits now, the fans still spin freely, its a bit dusty, but nothing like as bad as most pc's, and theres no swollen caps or anything. Would it be worth swapping them anyway?
The Li-ion battery seems to be dead, so i'll leave it out if it will boot without it, the coin cell had 2.8 volts in it, but i'm going to replace it anyway.
It very interesting to see how its wired, with the video passing through a second board bit like a 3dfx voodoo card but with added functions, like gdrom drive interface.
Is there anything else I should do while I'm in there apart from cleaning? Was thinking of replacing the gpu fan too.
Ian
obcd
3,830CR
If your gpu fan isn't noisy and if it's running fine when you power the lower case, it's probably not needed to replace it. Just blow the dust out with an air compressor if you haven't already done that.
Have you checked the 1 Farad clock capacitor on the bottom board for leaking? It's close to the border with the gamepad connectors. (Oposite corner of CPU) If that capacitor leaked, you better remove it and clean up the spillage as it's corrosive and eats away the pcb traces.
The most logical next step of fault finding is transferring one board at a time to a known working unit so you know what boards are working and what boards don't work as pretty much any failure will result in the 'no video' issue.
IanH
277CR
Hi, Ive been having a look at the boards, the backup cap has started leaking, but there doesn't seem to be any corrosion, I've taken it off and cleaned the board with some meths and some cotton bods.
Can this replaced with something else like a button battery and a diode to stop the charging voltage?
The gpu fan spins ok , but the bearings are on the way out so going to replace it.
Ian
obcd
3,830CR
You don't need to replace that baseboard capacitor. It's just there to keep the ram and real time clock powered when you replace the CR2032 coin cell (at the other side of the pcb)
So, wthout that capacitor, your chihiro will loose it's setup when you replace the cr2032. With that capacitor, it won't if you replace that coin cell before it runs flat. (it's always flat I know.)
