Virtua striker 2 graphics problem
Druby1977
1CR
Hello from East Yorkshire!
This is my first post here, so here goes....
I have a serious problem with the game graphics on my virtua striker 2 cab. (see photo)
It has been threatening to throw a wobbler for a couple of years and usually sorted itself out after a couple of "turn off and on" procedures. Sound and everything else is fine. I would appreciate any advice on possible repairs or just ditch it and convert it. I would really like to keep it original.
Thanks in advance for any advice.
obcd
3,830CR
Have you checked your power supply output voltages? The original power supplies used for model 3 sometimes have issues when they start up. We have a sege rally that uses the same hardware, and occasionally we have to restart the machine in the morning cause one side didn't start.
Vamino
Insert coin(s)
2,698CR
Could be voltage like obcd states, Model 3 are pretty power hungry stacks. It could also be a romboard/filter board fault or at worst it could be a videoboard fault.
Virtua Striker2 was released on 2 different stacks. If it's Step 2.0 then the videoboards are quite expensive, so it may be cheaper just buying a step 1.5 stack if it proves to be a videoboard fault.
Check the voltage first like obcd says.
