Volume pot - suitable?
4,058CR
I was asked about suitable pots for Atari volume controls by PM today but after researching it a little, I want to know myself now
To take my Asteroids Cabaret as an example, but my Tempest is just the same, IIRC the manual doesn't give a value but I think it's a 50R wirewound pot (manuals not to hand right this moment)
Would a 1W wirewound pot be sufficient or does it need to be beefier?
RS Part Number 173-164 looks to me like it may fit the bill perfectly but I wanted to be sure.
The other thing is that's a Linear pot as opposed to a logarithmic pot but TBH, I've not got a bloody clue what that means anyway
trm
2,877CR
Linear vs Logarithmic.
A linear pot means that when you set the pot to half-way deflection, the resistance is half of the maximum. Move it to 3/4 of maximum and the resistance is 3/4 of the max resistance. If you plot the pot position against the resistance you'd see the points made a straight line at 45 degrees on the graph. You would (but for the caveat later) use these e.g. on motor controllers, so if you want to move a robot arm the deflection of the pot is directly proportional (linearly) to the movement of the arm. This is the green line on the graph below.
A logarithmic pot is entirely different. If you plotted a graph as I mentioned above, you will see something like the blue line. Log pots are normally used as volume controls as hearing works logarithmically - moving from volume pot from 10 to 11 on a log pot doesn't make the sound a 10th louder which it would on a linear pot.
And just to make this nicely inconsistent, most arcade boards use lin pots for volume controls! This is probably because you can approximate a log pot with a lin pot and external resistor, and proper log pots are more expensive.
This graph shows a plot for lin (the f(x) = x line in green) and a standard log pot (the f(x)=log(x) plot in blue). The linear plot has a linear directly proportional relationship between the input value x and the output value, also x. The logarithmic plot has a non-linear relationship plot.
Sorry can't help on the other point till later tonight when I can look at the schems; I'm meant to be on day 2 of moving house with my bro and sis-in-law but I seemed to break my toe half an hour ago so I'm just strapping it up
trm
2,877CR
Is the volume pot before or after the power amp? If before then I'd say 1 Watt was overkill and plenty, but if it's after the power-amp then it'll need to be 5 or so Watts at least.
4,058CR
[Snippity Snip] Cheers dude, that's perfectly clear
Ouch! That sounds like a perfectly reasonable reason to bail and head for the pub to me
I'll dig the schems out in a minute but I would think the answer is that it's pre amplification but honestly can't remember at the moment.
4,058CR
Actually, it looks like it's between the amp and the speaker
4,058CR
Ok, found it in the Asteroids Deluxe manual.
Original is a 50R, 12.5W Wirewound Rheostat
Closest RS have would cost £40 + VAT
Farnell have what looks like the exact item - £30.87 + VAT (and US Stock)
Will go on a hunt...
