Weak deflection ?
taito6581
64CR
I've got this 17" screen hooked up to a newer Wei-Ya chassis.
The lower half of the screen (top half is left on the screenshot, bottom half on the right) has all the lines further and further apart so my question is if the deflection coil of the screen is wonky or is the chassis incorrect ? its listed as a 17-21 inch compatible chassis.
Not visible on picture is that there is a wobble on both x and y axis. not really visible during gameplay but on static screens its quite annoying.
Horizontal impedance is at 2.2
Vertical impedance at 55.3
And these 60-in-1s generate GREAT test patterns, too
Opinions and suggestions welcome.
andrew96
899CR
have you got a field linearity (also known as vertical lin) pot on the board? the favorite is to just tweak this when the picture does not fill the screen resulting in this issue, if only the ops moved the shift pot then the amp pot these things would not occur perhaps, many a monitor i have found that pot shifted just so it fills the screen!
taito6581
64CR
The board has a 'vertical lin'(e) and this fixed the rolling over on itsself but no the screenlines becoming further apart the further down the crt we go.
taito6581
64CR
then this is clearly not the adjustment we are looking for
the chassis has a low/high impedance setting. ill see what it does on the other setting tomorrow. and if i really feel like it move the chassis to a 21" tube.
taito6581
64CR
Swapped the 'high/low impedance' switch and there is some improvement, the empty lines inbetween are smaller but the test rectangles still get larger and larger the more we get to the bottom of the screen.
RGP
Meeter & Greeter
2,039CR
Andrew is right, normally it is the fault of the vertical linearity setting being used improperly.
But can I throw in here that i've had this issue on a number of chassis with the B+ voltage being just a fraction too low.
Without knowing exactly what make/model the chassis is I can't advise further but i've recently had a G07, 900E and a Selti (copy of a Hanty 900) all giving this kind of issue but upon correction of the B+ the problem went away - that's become one of my first checks now with monitor issues.
andrew96
899CR
Yep RGP your right, B+ volts can indeed cause this trouble, Recently i had the same with a hanty 9000 which i put the normal hr2025 in when it needed the the more rare type, and that caused the supply to the field stage to be to low and all sorts of linearity troubles!
But sorry I don't know your monitor well either so cannot advise further either
taito6581
64CR
Chassis should be a WeiYa C2621HR (http://www.weiya.com.tw/products_detail.asp?le=english&fid=30&pid=208&tCatName=CRT%20CHASSIS)
As the tube is 17/18" and not 21" i'll transport it into a 21" tube cabinet where the flyback went out with a bang. A vertical linearity does not exist on the chassis.
And I have no idea where/what the B+ voltage is
(ive been doing arcade cabs for a few years now but only recently started tinkering with busted crts - but learning fast
gunblade
9,096CR
well I may be wrong but I am quite sure the ch2621 chassis is a low impedance chassis-therefore the vertical deflection resistance should be between 9 and 15 ohms
your yoke is high impedance,55 ohms
taito6581
64CR
Update : Put the chassis in a french NStyle cabinet with a 21" and the picture is now stable (tube has impedance of 2 on horizontal and 7.5 on vertical).
However the HWidth pot on the chassis seems non-working right now
and the VWidth wont stretch it enough to go "full height"
Thats what you get with universal chassis' methinks
And the tube is ticking a wee bit too much so it clearly had its use in the past.
But I'm still open for ideas.
