WG K4600 issues
Stickman
355CR
So I have a K4600 that was in bits when I got a Gorf to restore, I have recapped all the boards, had to do a temp fuse set up as the main fuse on the chassis is missing, fired it up and I got the usual thuds static and noticed some colours on the screen.
So turned it all off and plugged in the game boards etc. Turned it on and there always a crack, a spark from somewhere and the garage breaker tripped. I have been all over the chassis and cannot see anything that has fried. But it is now completely dead. I have used the Randy Fromm flow chart, checked that main transistors and they measure out ok, checked for B+ and if I go between the blue wire on the transistor as suggested and the chassis ground on DC I get nothing, but I do get AC at 120v. strange that it blew after I connected the video in from the RGB card. I also have two types of interface card as shown below, it had the one in it with the single VR201 on it. Any ideas, I will reach out to Gunblade and TB2000 to see if they do repairs on these chassis’s
tb2000
3,584CR
Are you sure it's not something wrong with your isolation transformer? These chassis can be a pain really as the lopts haven't been reproduced as far as I know, so if the lopt's gone bad (unlikely, but if it has it can make the whole chassis pretty much dead) then you'll have to swap the chassis out (or maybe the whole thing). I did have one with a working lopt but I used it in a repair a while ago.
Stickman
355CR
I have 120v from the isolation transformer, I did wonder if it was the lopt but that looks ok from an initial look.
Are you able to test them Tony?
tb2000
3,584CR
I can take a look as I do have a yoke for one of those to test with, in fact I have a whole monitor minus working lopt as I say and minus crt (was necked when I got it). I know that the three plug in cards I have are working as they worked in the last chassis I repaired. Hopefully it's not the lopt!
Edit: By the way, apparently if you remove transistor TR353, that will disable the ocp circuit - if it works and you have horizontal deflection then hopefully that means the lopt is also ok and you probably have a voltage regulator problem.
tb20002021-04-25 19:05:15
Stickman
355CR
I pulled the chassis out today and had a look around, I found that a track had blown, see pic between pin 4 & 5. Looking at the schematics this is part of the GND. As this blew the second time of turning on I was wondering if the degaussing kicked in as this is connected to pin 1 of the coil plug. I did post on a Facebook group for monitor repair and someone just said they need an isolation transformer, I am now thinking is the transformer I have used unsuitable, or is there a fault in the degaussing circuit, I checked the coil which was 15 ohms and not dead short to the tube surround.
Stickman2021-04-26 21:37:46
Stickman
355CR
ok done a repair, installed new isolation transformer and it fires up!
However get the following on the screen and the B+ starts at 114v and drops to 100v DC, I am hoping it is not the fly back and something on the power regulator board, any pointers appreciated.
Stickman
355CR
This is fighting me all the way, checked the power board as I do not get the 127v on B+ only 100v. Looking at the schematics I get 142v on pin 4 which is about right and then on pin 5 100v checking back everything seems ok, I am thinking maybe something is pulling this down. I did a change of a resistor on the neck board for brightness issues but this had no affect. I did notice that the neck board has been broken and some pretty crappy repairs made, I had to do a jumper on one track as the repair was terrible.
Any other pointers from anyone, I may give up and send off but I do enjoy trying to do these things myself if possible.
