WG Screen wobble
Sluggy
73CR
WG K7000
When power up you get about 4 mins of screen wobble, Not bloom, not sync, not roll
the screen wobbles, any thoughts?
Powered by Iso trans but running at 136volt.... bit high but would that cause it??
If it remained throughout play I would say power wobble but it goes after about 4 so sort of ruled that out... tried dropping the Iso out of the machine and putting the other side of the room but still happens.
gunblade
9,085CR
check b+
19" should be 123v
25" should 130v
first things to check are dry solder joints and caps c57 and c56, i don't think regulator ic is problem as fault would be permanent
another thing to check is ptc, you can eliminate that by removing from circuit (r105)
Sluggy
73CR
...... oh yeah forgot that bit..... 19"
What about that input power being 136v looks like max tolerance would be 132v?
