WG6100 fix
Monstermug
1,807CR
Repairing a wells gardner 6100 for a friend.
Symptoms reported: Fuses F101 and F100 keeps blowing. No picture. Game plays blind.
Solution: Replaced F101 and F100 with 5a Slow blow. Found three chassis mounted transistors had shorted. There were two floating wires connected to the chassis mounted transistors which I put back in its place (the pins going into the red connectors had popped out so it was just a matter of putting them back)
Low voltage section had faulty diode which I replaced. All major components in deflection tested against schematics and viewed safe to power up.
On power up, I get no spot killer, I get B+ and B- voltages. 19kv on the anode. (tested with HV probe). Trouble is no neck glow. It should be working! I've tested everything and it seems to be working but its not
At this point, everything seems to suggest the tube had died. Sensible thing was to test the deflection and HV boards in a known working tube but I wasn't prepared to do that.
Adamant that the tube was fine I went on to have another poke around.
Tested continuity in pins 9 and 10 and it shows a short (well little resistance which seems to suggest heater is fine)
Removed HV cage and tested all transistors, resistors, diodes and caps. They all tested within tolerance of schematics.
Tested my sanity by sticking in a known working deflection board but still same problem. Everything should work just no neck glow. I know my Atari brick is feeding the 10.6vdc. Only thing it could be is the wiring. So I got out my meter and tested for the heater voltage (should be about 7v at the brown and black wire terminals on the neck)
I got 0v.
Tested continuity for black wire. Good. Checked continuity for brown and none! Bingo.
the brown wire feeding the tube with the heater voltage was broken inside the crimp housing.
Soldered the brown wire directly back on and I got this after plugging it in :)
Glad the tube wasn't blown. Needs a little adjustments but I leave that to the owner to fiddle about with
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Another good write up and fix.
Must send mine down your way to take a look at for me so I can get my black widow workijgmfor the next meet.
Monstermug
1,807CR
Thanks for that. Yup looking forward to putting that wg6100 and my new one back together again. Got to pick up that dragon spirit pcb from you as well. Probably will be sooner than later.
